i am going to get a catch can setup soon but after today pulling intercooler off
its a bit worrying seeing oil just laying there would think with this much it would be blowing smoke
heres a pic but probably too hard to see
Posted 12 January 2012 - 05:43 PM
Posted 12 January 2012 - 05:49 PM
Posted 12 January 2012 - 07:35 PM
I am too scared to pull mine off to see the same thing. It is common on B4's apparently, especially when using too thin an oil. The top mount acts like a catch can. It can either be blowby from the rings, or a turbo seal.
That is a fair amount of oil there though lol, will be interesting to see peoples responses. Does you car go through oil? Mine doesn't change oil level wise. Do you get a puff of smoke on a cold start? Just a quick burn off?
Posted 12 January 2012 - 07:57 PM
It is common on
B4'ssubaru's apparently
Posted 12 January 2012 - 08:01 PM
Posted 12 January 2012 - 08:19 PM
^^^ yep catch can^^^
and clean your pipes out...than put a cup of petrol in your cooler, cap the ends and swish it around to remove the oil (do this a couple times) your cooler will work heaps better without the oil, as the oil acts as a barrier
Be sure to let the petrol dry out thoroughly better re-installing
Posted 12 January 2012 - 10:06 PM
