cam belt came off after accident
12 replies to this topic
#1 tmh983
tmh983
  • 358 posts
Posted 12 April 2012 - 07:02 PM
Have been helping someone out who had a front end crash in a gen3 lib. Unfortunately one of the radiator fans got pushed back and smashed the cam cover and the belt has come off.
On the weekend we are going to see if we can refit the belt and then do a compression test. It doesn't seem to have damaged any of the pulleys, but I won't know for sure until I can get it apart and have a look.
Is there any chance at all that it won't have bent the valves or is it pretty much guaranteed to have done damage?
#2 alexGT
alexGT
  • 1970 posts
Posted 12 April 2012 - 08:05 PM
EJ motors are interference motors. if the motor was running at the time you will be in trouble.
#3 Xon
Xon
  • 1535 posts
Posted 12 April 2012 - 08:12 PM
Might have some bent valves and rooted pistons going on...
#4 Scott
Scott
    Formerly LiBeRtY Gx AwD
  • 1498 posts
Posted 12 April 2012 - 08:16 PM
if the car stalled before the belt came off you might be alright happened to a mates wrx
he ran up the back of someone but the car stalled as he hit the brakes with no clutch, the hit made the belt came off but engine wasnt running
if the car ran until the belt came off then it would have stalled because of internal damage :(
#5 Jimbo
Jimbo
    Livin' the Legacy
  • 2771 posts
Posted 12 April 2012 - 09:14 PM
AFAIK the N/A motors are non-interference.
I had a timing belt tensioner explode while i was driving around in my old wagon and shit went everywhere. Car came to a griding halt. Slapped on a new belt and it was apples.
Your mate may be lucky. I reckon it would be quicker to whip the intake/zorst manifold off and have a look that way.
#6 tmh983
tmh983
  • 358 posts
Posted 12 April 2012 - 09:15 PM
Hmm, i've got no idea if the engine had stalled on impact, but I know for sure the guy has been trying to crank it on the starter since the accident, so theres is probably a good chance the valves would be bent by now.
I guess there is an extreme outside chance that the valves would have come to rest in just the perfect positions so they are clear of the pistons, but thats proably just wishful thinking.
Ah well, I guess this crash is gonna cost the guy a lot more than he first realised.
#7 93tzlegacy
93tzlegacy
  • 1470 posts
Posted 12 April 2012 - 09:19 PM
just put the belt back on, will be good 99% of the time.
0415 522 512
#8 tmh983
tmh983
  • 358 posts
Posted 12 April 2012 - 09:23 PM
wikipedia says all ej's post 1996 were interference engines. Will have to wait until saturday to find out the extent of the damage.
#9 bobbyjimmy
bobbyjimmy
  • 1287 posts
Posted 13 April 2012 - 12:05 PM
Only early EJ20/22's are non-interference.
#10 alexGT
alexGT
  • 1970 posts
Posted 13 April 2012 - 12:38 PM
I know of a gen2 with gt-b motor that had a very small hit and it bent valves.
you really aren't going to know until you put a belt on and try?
#11 tmh983
tmh983
  • 358 posts
Posted 13 April 2012 - 01:12 PM
yeah thats right, no point speculating really. We will cross our fingers and put the belt back on tomorrow and see what happens.
#12 tmh983
tmh983
  • 358 posts
Posted 13 April 2012 - 07:27 PM
so the verdict is........... one farked engine.
The damage was a lot worse than I first realised. After I took the bumper off I could see the full extent of the damage. Looks like he's hit a towbar or something.
With the cam cover off, you can see the belt has come off the back side of the crank pulley and was completely jammed.
The belt is r/s
I rotated the cam pulleys by hand to a position where both valves should have been closed and ran a compression test. LH bank is fine, RH bank has zero compression on both cyls.
The upside of this for me, is that I am probably going to buy this wreck and use it for a cheap manual conversion for my car. its only got 104,000 k's on it and the dual range box is tight as. Plus theres plenty of good parts i can wreck out to whoever wants them.
#13 Scott
Scott
  • 1498 posts
Posted 13 April 2012 - 09:44 PM
damn
good for you tho haha
