Engine block question
Posted 02 November 2014 - 08:35 PM
Reason I'm asking is I threw a Conrod so my gen 3 b4 is ratshit
However I can get a ej20h long block for cheap as chips can I use this block an put all my gear on it ??
I don't have enough money to just buy a gen 3 b4 motor so only reason I'm considering this if not then I'll hav to wreck it down an I don't wanna do that
Posted 02 November 2014 - 10:03 PM
Gen 3 is a 8 bolt block.
Gen 2 is only a 4 bolt block, but it can to modded to work.
That's the only changes that I know, Hope it helps.
Posted 03 November 2014 - 08:24 AM
Posted 03 November 2014 - 08:26 AM
Wat u mean 8 n 4 bolt block wat bolts?
bellhousing (transmission to engine bolts)
Posted 03 November 2014 - 09:57 AM
I would think the Gen2 heads couldn't be used as the intake manifold bolt pattern is different?
Also, aren't all the late TT's 9.0:1 static comp ratio? The Gen2 would be 8.5:1? All the later GT-B's were so one can assume the change made it's way across to the RS-K? Correct me if i'm wrong?
Posted 03 November 2014 - 09:58 AM
Posted 03 November 2014 - 09:59 AM
From memory, i think you have to do something funky with it so the starter motor fits.
Posted 03 November 2014 - 10:04 AM
Jimbo is correct on all counts.
Static compression isn't compatible for the Gen3, the tune is all out.
It'll work, it'll run, but it'll go like arse.
Contact Ichiban, surely the lads there have something to suit?
Posted 03 November 2014 - 02:25 PM
Posted 03 November 2014 - 06:38 PM
