Click here for EJ20K goodness
Current Mods:
Engine:
- V4 STi Conversion
- VF23 with Billet 18G compressor wheel
- DW200
- 3" TBE with Xforce Muffler
- AM Auto Twist mount
- AM Auto front mount intercooler piping
- Alloy Radiator
- Grimmspeed AOS
- PSR EL Headers
- Halfmoon Sump
- Enduring Solutions ECU
Driveline:
- V4 STi Driveline (4.44 close ratio gearbag, R160 Viscous LSD)
- Exedy HD Clutch
Suspension and Wheels:
- BC BR Coilovers
- STi pillowball lateral and trailing links
- Whiteline 22mm Rear sway bar
- Whtieline 22mm Front sway bar
- HD rear swaybar links and mounts
- Advan RG 17x7.5 +48
- Achilles ATR Sport 2 215/45
- Whiteline rear camber bolts
- 2.7 STi Steering Rack
- Cusco Strut brace with master cylinder stopper
Brakes:
- 4/2 Pots
- Slotted front rotors
Exterior:
- GTB Limited Front bar
- Legacy bootlid and rear garnish
- GTB Projectors
- G-Square Fender Trims - In storage for now
Interior:
- S401 Momo steering wheel
- JDM RS Camo interior
- Legacy facelift switches
- Legacy steel scuff plates
- Legacy floor mats
- AEM Wideband
- Prosport Halo Boost Gauge
- Kapp Industries Fire Extinguisher Bracket + Fire Extinguisher
- STi Duracon Shift knob
- Redline Goods red stich shift boot
- STi pedals
- Gen 4 3.54 Long Ration 6 Slotter
- 3.54 Suretrac diff
- GC Alloy control arms
The beginning:
The story begins a few months ago when Ty announced he had just bought another white gen 2 RX for $500 with a blown headgasket and didnt know whether to part it or fix it for his missus to use a shitter daily. I suggested he part it as I wanted the climate control and all those neat bits that are a pain to assemble without a complete car to pinch from. Someone then had the smart idea of swapping cars. We/Id fix up the RX and swap in all my good bits, return my current car to stock and he gets my car. Genius. It later turned into swapping the current owners RSK engine out and getting the car for payment. So after 2 months of pestering Ty to pick it up, it has finally happened today! Ive joined the white crowd!
She needs a lot of work but im looking forward to basically stripping it down and rebuilding it. Engine is smooth and strong and is noticeably better than my asthmatic 2.2; even with nearly 300k kms
Needs some body work but will probably just get them from a wrecker.
Also needs a very good wash inside and out. Has been sitting for a while so the outside is covered in paperbark leaves. Previous owner was a smoker so entire interior will be getting stripped and swapped for my interior. Dat cream tho
Will be dying the headliner and carpets black most likely to freshen it up.
What this is all for
Jumped at the oppertunity to get the gaskets from the US when Ty ordered them for his Foz. 226 delivered for every engine gasket. Bueno
Heres the to-do list so far:
- Replace Head gaskets
- Paint valve covers (black wrinkle)
- Paint intake manifold (red for extra kw)
- Rego/Roadworthy
- Strip and replace interior
- swap my good bits in
- Paint limited bar white (DIY)
- Get bootlid welded up and painted
- Skids
I plan on documenting the fuark out of the engine work cos I know you ers love that stuff
