25D - Crank no start/Warning lights no key
17 replies to this topic
#1 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 17 January 2015 - 08:56 PM
Can i get a WTF. So when the RX engine died earlier tonight i put it down to fuel. Ive chucked 8ish L in it and still no start. The other weird thing that makes me think its not fuel is the dash warning lights (Oil, ABS, AIrbag etc) stay on albeit dimmer even with the key removed until the battery is pulled. There are no blown fuses and was running and starting perfectly fine up til now. My first plan for tomorrow is to pull a fuel line to see that im getting fuel as the dash lights could be unrelated. Ty seems to think its the key barrel which would explain the dash lights but i thought id throw it out there. Thanks in advance
Potato photo but you get the idea. Christmas tree of lights with the key off
inb4 get an SSM :P
#2 Morgan
Posted 17 January 2015 - 09:16 PM
Faulty/busted alternator?
#3 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 17 January 2015 - 09:17 PM
Should still run off the battery though shouldnt it? Ive been using the silver cars battery so i know its good
#4 Morgan
Posted 17 January 2015 - 09:19 PM
Properly reread your explanation (skim read before..)
I just know last time I had a Christmas tree, I waited by the side of the road for 4 hours for the NRMA to come and replace the alt haha.
#5 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 17 January 2015 - 09:25 PM
All good morgadore. Free bumps if anything ;)
#6 RX25SE
Posted 17 January 2015 - 09:31 PM
Could be this. Try pulling the B+ wire off the back alternator and see if it kills the lights.
Maybe a faulty relay back feeding the ignition circuit, try pulling relays one by one.
#7 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 17 January 2015 - 09:38 PM
Would that do something even if the car/alternator is not running?
#8 RX25SE
Posted 17 January 2015 - 09:47 PM
If the alternator is forked, it can feed voltage back into the ignition circuit.
If you pull the B+ wire with the engine off and the key off, and the lights go out, alternator is forked.
#9 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 17 January 2015 - 10:01 PM
Ill add it to the list of things to try haha
#10 LPM_B4
LPM_B4
    LPM_FOZ
  • 854 posts
Posted 17 January 2015 - 11:14 PM
White gen 2s are cursed :P
#11 Cam.
Cam.
  • 4906 posts
Posted 18 January 2015 - 12:27 PM
Check earths :)
Asb2OgK.jpg?1
#12 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 18 January 2015 - 03:13 PM
It's working again. Must have been a fuel issue or its time of the month
#13 RX25SE
Posted 18 January 2015 - 03:21 PM
So what caused the dash lights to stay on?
#14 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 18 January 2015 - 03:57 PM
I have no idea haha. Fuel pump sticking trying to prime maybe?
#15 RX25SE
Posted 18 January 2015 - 05:14 PM
Doubt it.
Is it still doing it? Curious to see what it is.
#16 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 18 January 2015 - 05:34 PM
Doubt it.
Nope all fixed now
#17 CodeBurn3r
  • 4048 posts
Posted 21 January 2015 - 09:18 AM
#18 Barbbachello
Barbbachello
    Touring Bruce
  • 6496 posts
  • Interests:Docking
Posted 21 January 2015 - 09:35 AM
