Why is my green power light contiounisly flashing?
Also when I take off my car gives a falt and the acceleration you can put your foot too he floor and it slowly creepys up doesnt take off!
01 Subaru outback HELP!!
can anyone help! power light flashing
Started by mickalsuburu01, Jan 29 2015 03:43 PM
5 replies to this topic
Posted 29 January 2015 - 03:43 PM
Posted 29 January 2015 - 03:56 PM
gearbox or TCU issue
There's a way of checking the TCU fault codes stored around here somewhere.
FOund this
On-Board Diagnostics for the 4EAT Auto Tranmission
There are two varieties of trouble codes from the Transmission Control Module (TCM); Existing and Previous. Here is how to read the code without the Select Monitor tool.
Existing:
11) Duty solenoid A
12) Duty solenoid B
13) Shift solenoid 3
14) Shift solenoid 2
15) Shift solenoid 1
21) ATF temperature sensor
22) Mass air flow signal
23) Engine speed sensor
24) Duty solenoid C
25) Torque control signal
31) Throttle position sensor
32) Vehicle speed sensor 1
33) Vehicle speed sensor 2
All solenoid issues, "detect open or shorted drive circuit, as well as valve seizure". All sensor or signal issues, "detect open or shorted input signal circuit".
Existing:
- Move gear selector to D
- Turn the ignition switch to On
- Move the selector to 3, 2, then 1st gear.
- Depress the gas pedal
- Move the selector to 1st gear
- Move the selector to 2, 3, then D gear.
- Light flashes 4 times per second, you have a faulty battery.
- Light flashes 2 times per second, all is normal.
- Light remains on, check the inhibitor switch, diagnosis switch, wiring, TCM, etc.
- Trouble code (see the next section).
- Long light pulses (~1.2 seconds) indicate "tens."
- Short light pulses (~0.2 seconds) indicate "ones."
- Count the long, then short pulses.
- Interval between codes are ~1.8 seconds.
- Codes will repeat.
- There are about 13 codes ranging between 11 and 33.
11) Duty solenoid A
12) Duty solenoid B
24) Duty solenoid C
Posted 30 January 2015 - 10:01 AM
Im in nsw, and have only recently got the car
Posted 30 January 2015 - 10:10 AM
Checked the codes yet.
Posted 30 January 2015 - 12:46 PM
Not yet mate will do this arvo after work
Posted 31 January 2015 - 04:51 PM
Did nothing light stayed on
