Basics required for track work
Posted 24 February 2015 - 03:51 PM
I've got an my00 gc8 and am looking to be doing an occasional track day with it, what im interested to know is what are the basics suspension wise that are recommend to get the best out of it.
This car is daily driven so I don't want to go nuts and end up with a track pig, just simple stuff that make a big difference
Cheers Brett
Posted 24 February 2015 - 03:55 PM
Front and rear sway bars with end links and mount supports
coilovers
Strut tower brace
Brake pads, braided lines, good fluid, new rotors
Good tyres
Posted 24 February 2015 - 03:59 PM
I would suggest make sure it is reliable and all levels are full and there is nothing loose in the car, then get out there!
Best you track it first to find the car's (and your) strengths and weaknesses. Take an accurate tyre gauge and a small compressor with you so you can monitor and adjust the pressures. You will be surprised how much they will change.
If you do need to mod it beforehand, I would start with the brakes.
Posted 24 February 2015 - 04:19 PM
Posted 24 February 2015 - 04:55 PM
2. new brake fluid
3. a set of track rotors - $40 cheapies are what i have.
4. a set of track pads - QFM's is what i use
5. rear swaybar + links + mounts
6. front swaybar + links + mounts
7. coilovers/suspension upgrade
8. strut braces
8. wheels and tyres
Posted 24 February 2015 - 05:00 PM
You will still have heaps of fun in a stock car but obviously if you want to go faster you will need to start modding.
Posted 24 February 2015 - 05:02 PM
Posted 24 February 2015 - 06:41 PM
brakes brakes brakes!
280+ rated fluid
slotted rotors
pads rated up to 800 deg (A1RM or similar, great value)
COOL DOWN LAP if you want your car to survive also...
Posted 24 February 2015 - 06:48 PM
If you run track tyres, then you will need to sort out the brakes.
Posted 24 February 2015 - 07:12 PM
Normal make sure I don't have any leaks and everything that needs refreshing has been. Depending how the budget look a set of sway bars and shocks will be on the list
Posted 24 February 2015 - 08:29 PM
Yup, just change the brake fluid, fit the semi's and go have fun. If you fit new pads, do it well beforehand and bed them in on the street.
Posted 24 February 2015 - 11:12 PM
Posted 24 February 2015 - 11:41 PM
I wouldn't worry much about roll bars and links, just a decent set of coil overs. BC's are pretty good for the money, with front 10kg and rear 8kg spring rates.
By the time you've spent on roll bars and links you could put the extra money to a set of BC's. They are surprisingly compliant with those rates but if you know someone I'd go for a ride first to see if you like it.
I'm running a set of Apexi struts that MCA have completely rebuilt recently and this is a setup they recommend as a good start.
Alignment of 3.5deg camber (maybe 2.5 if it's to remain a streeter) with neutral toe and max caster(again caster not entirely nesessary). Rear Neutral and around 1.5deg camber.
DS2500 on the front and rear and a cheap set of RDA's upfront. I find RDA's last better than DBA's as well. Cool down essential as I've pitted with the bastards on fire. They kept braking though.
As Jase and a few of the boys have mentioned fluid is key too as is bearing grease especially as you are running Semi's.
There a few more minor tricks but that should get you into happy fun times.
Posted 25 February 2015 - 12:30 AM
Hire a new Commodore for $100 a day and do a track day in it... Saves wear and tear on your car. Cheaper if you crash it too.
Posted 25 February 2015 - 03:47 AM
Posted 25 February 2015 - 05:19 AM
What's the GTR? Sounds 34 or 35 by your expensive parts comment.
Posted 25 February 2015 - 09:15 AM
I tracked my Daily for a while (before it became a weekend Track hack)
Good Rotors never go astray.. I use T3 DBA.. but then i do Winton which is hard on brakes!
Pads.. A1RM - Cheap and handle the heat but dont take too long to warm up for street use (THIS IS IMPORTANT!)
Brake Fluid - Castrol SRF is what im swapping to but at near on $80 Per Litre its pricey for starters.. Standard Castrol React/Response are one of the highest temp Super DOT4 Fluids and at about $12 per litre and you can get it from Supercrap its probably the best bet.
Braided lines are great.. i dont have any yet lol.. my pedal is a bit spongy but then i always tap the pedal before i hit the brakes (habit from old days of sliding callipers where Pad Knockback is much more pronounced)
Change your oil! .. Fresh oil before a track day!
Check the fluids.. Coolant, Power Steering (PS Fluid is always one that people are surprised about but you'll be surprised how friggen hot that shit gets and if the cap isn't great it ends up everywhere!
Tyres.. IMO as long as they aren't LingLong Nangkangs you'll be fine... Trash out a set of Street tyres until you get better and can put good tyres to use.
I run 2.5 Front Camber and 1.5Rear
I don't subscribe to needing Coils.. but then i have Billies and they are (IMO) better than cheap coilovers
Sway Bars, Rear is more important.
Strut Braces do SWA - only once you are pushing it will you notice it..
The GC8 is a pretty decent chassis to start with.
I'm a bit of a Stickler for this (but then again i haven't broken any gearboxes!) New Gearbox Fluids every few track days... I like Castrol Syntrax.. it's not cheap.. and only comes in bloody 1L bottles... but in my own FIRST HAND experience.. it is my preferred fluid. My box has a shifty 4th gear syncro and doing this has kept it going for over half a dozen Track days now.
Anything more than these basics and you're wasting your money...
Once you are doing plenty of days you will learn what your car needs.
Posted 25 February 2015 - 09:18 AM
This thread seems like a candidate for a sticky
Posted 25 February 2015 - 11:50 AM
What I would do if I had a completely stock MY00.
Oil filter + Oil change prior ($50-80)
Slotted rotors + A1RM (front only - $300 or so)
Rear sway bar + HD links (~$300)
Brake fluid flush (DIY + fluid $20 for 2 500ml bottles (super dot4 280deg+)
Tyres with decent tread (varying). For a stock powered MY00 this isn't critical.
Gopro/cheap camera setup in cabin, great for analysing your laps afterwards (or inbetween breaks) great for seeking advice too.
This is plenty to get you going, and your car will still have higher limits than you can achieve (if you are a novice driver).
Posted 25 February 2015 - 12:15 PM
its a 32 but it's a very clean one and to replace it for one in equal condition id be looking at 20k compared to the 5k that I bought my gc8 for.Too true, you could probably pickup a whole GC8 for spares for a fair price.
Awesome pads and fluid change were first on the list of things to do and everyone is backing up what I was thinking and by the sounds of it these really don't need much to become and enjoyable track car
