I have recently gone to a track day and the brakes where bad from the get go. This would also come down to that i had bad pads probably wrong dot brake fluid. But what i do know is after taken out a track ready car, i need a decent upgrade.
Looking at going the 4/2 pot set up and from what i have found and have questions about are the following
Rotors im looking at DBA T2's
4 Pot fronts i need a 295 Rotor, but found 24mm and 25.4 thickness. Not sure on what i need or why the difference?
2 Pot rears i need a 290 Rotor, but found 10mm and 18mm thickness. Im guessing that i need an 18mm?
Dont know if i need a 170 or 190 hand brake or what i even have atm
As ill be doing a few more of these track days i wanted to know if Gc8 wheels would fit (just easy cheap wheels to put some semi slicks on)
Also what off set should i be looking for with after market wheels.
gc8.JPG 106.55KB 17 downloads
Either of these brackets fine Flat vs Kartboy
Flat braket.jpg 56.85KB 18 downloads
Kartboy braket.JPG 112.59KB 17 downloads
If doing some more track im guessing best bet is to get 5.1 Dot Fluid
Would i have to upgrade the brake booster or will a support bracket help?
Lastly braided lines, do i get them for my car or an 06 wrx that i get the brakes of?
Brakes pads are undecided as of yet
I know this is still a lot of info to be asking but i did try my best to find as much info as i could. Cheers in advanced and im open for any changes and suggestions.
