Transmission mount NVH
Posted 21 April 2015 - 05:23 PM
I was aware that there would be an increase in NVH.
I re-used my current header gaskets as I had to remove my headers and cats to access the required nuts/bolts.
Upon start-up I noticed there was more noise, especially boxer rumble, and a slight burning smell and hissing in the engine bay, something that I have attributed to as failed gaskets, even though they were torqued down correctly. I have already sourced some replacement gaskets.
The NVH imo is borderline unbearable.
Have any of you experienced something similar with installation of a Group N tranny mount?
I have Group N pitch stop mount already in my car and I have engine mounts to put in too.
Do you think the bush has affected the tailshaft in relation to the transmission box?
The driveline doesn't feel stiffer, but this may be because of the header gasket leak.
Cheers.
Old Chinese Proverb: Experience should fear the strength of Youth
Posted 21 April 2015 - 05:55 PM
Posted 21 April 2015 - 06:08 PM
is that a big lump of poly in the middle? No wonder they increase NVH.
The group N mounts are still rubber -- just without compliance gaps like the std mounts.
Is this the install process - shove Rallitek block of poly into std mount ?
http://legacygt.com/...82.html?t=45482
If so - try filling the mount with sika 255 instead.
Posted 21 April 2015 - 06:16 PM
I have a group N tranny mount, but its on a manual. NVH increase was noticeable but not major, and really only when punching it. Changing gears definitely feels better though
Posted 21 April 2015 - 06:18 PM
Posted 21 April 2015 - 06:42 PM
Posted 21 April 2015 - 07:11 PM
Has anyone heard any feedback about the soft version? I have one sitting here I haven't put in, wondering now if it's worth it?
Mark, did you get yours in?
Posted 21 April 2015 - 07:13 PM
Posted 21 April 2015 - 08:42 PM
Does that sikaflex 255 go hard or stay a bit soft like butylmastic sealer stuff?
Posted 21 April 2015 - 09:35 PM
It stays pretty rubbery.. datasheet says Shore A hardness of ~60, which is approaching tyre-tread type material.
Posted 22 April 2015 - 12:18 AM
Still do the ALK, it's great and next to no NVH, except for Harshness only, from the front end being more stiff.I changed the lower shift bushes and the 'positive shift kit'... took them out a couple of weeks later because of the noise, way to annoying to drive to and from work everyday, decided I'm not changing anymore bushes or adding the anti-lift kit I had planned
Posted 22 April 2015 - 12:20 AM
Posted 22 April 2015 - 05:31 AM
I see, I shall look into it againStill do the ALK, it's great and next to no NVH, except for Harshness only, from the front end being more stiff.
Have you done it?
Posted 22 April 2015 - 08:15 AM
Sure haveI see, I shall look into it again
Have you done it?
I rate it above a rear swaybar.
Posted 22 April 2015 - 09:12 AM
Thanks, I had it totally crossed off my list because I read it makes a fair bit of noise
Posted 23 April 2015 - 06:56 PM
What I want to know is are there any benefits of my mount bush cuz I don't want to waste my time and gaskets only to realise the NVH is unbearable and the benefits (if any) are negligible, in which case I'll remove the RalliTEK bush.
I remember Cam saying in my build that pitch stop, transmission and engine mounts are some of the best mods you can do.
I have STi engine mounts to go in too so is everything worth it, especially the engine mounts?
Cheers.
