hey guys my rex (06 wrx) needs to get the power steering pump rebuilt can anyone recommend any good places and their prices if possible?
thanks
power steering pump
Posted 01 June 2015 - 04:22 PM
Posted 14 June 2015 - 09:16 PM
i feel as if these things are shocking ..my pump is a bit funky and my mates had to be redone, we both have 06,07 model WRX's aswell like you
Posted 15 June 2015 - 09:03 PM
Make sure the inlet hose to the pump is an absolute tight fit on the pump inlet (hoses go hard with age) and the O rings in the inlet fitting form an airtight seal. These things pull air into the system from there and make for noisy operation.
If the pump gets noisy after a belt tension, the shaft bushing may be worn and the pump is pulling air from the shaft seal. If this is the case, then it's reco time.
Posted 15 June 2015 - 10:39 PM
+1 for checking the o rings, also check that the high pressure line is torqued to the right spec. I actually thought I needed my pump rebuilt but the leak was fixed with a simple retorque.
