I recently bought an my00 Gc8 wrx. The previous owner has managed to dismantle the housing for the air flow sensor removing all of the mesh and leaving it an empty pipe. I've spent the last week trying to hunt down a replacement for it but have only had luck in finding the MAF housing/pipe in a non turbo rs. My questions are could i use this part? Am i able to simply buy some sort of replacement mesh? Does anyone know where to find this part new?
thank you in advance.
Posted 05 June 2015 - 12:56 PM
Posted 05 June 2015 - 01:18 PM
As if so it may have an aftermarket ecu tunning a map based tune?
Posted 05 June 2015 - 01:22 PM
Does it run ok like this?
it was running fine for the first month, now its started to run rich and is having hesitation when i start to accelerate
Posted 05 June 2015 - 01:27 PM
just the mesh, the sensor is still there
Posted 05 June 2015 - 02:20 PM
Posted 06 June 2015 - 12:00 PM
There seems to be a mixed response as to how this affects peoples cars, so i just want to have it back as stock.
Posted 06 June 2015 - 07:36 PM
the mesh is only to protect the sensor if by some chance a chunk of filter media comes off . as the sensor hot wire is running at 200 + degrees anyting that gets stuck on it will burn the wire out
the main reason its there is to regulate the flow of air over the sensor . in some cars in the usa they remove the mesh thinking it is better airflow but actually stops the ecu getting the proper reading
i can get you a used one in decent cond if u need one still
Posted 06 June 2015 - 10:59 PM
Posted 10 July 2015 - 04:18 AM
The mesh is there to correct the air flow over the sensor so as to provide an accurate reading. In reality it shouldn't make that much of a difference.
Replace oxygen sensors/leads/spark plugs and see how you go.
Also tagged with one or more of these keywords: air intake, maf, gc8
Suby Club Community →
Members Photos →
My GC8Started by DankyMatt, 09 Feb 2017 GC8, wrx, 1998, ej207 |
Model Specific →
Impreza / WRX / STi →
Builds and Projects →
GCEBE - Abrahams 1998 GC8 WRXStarted by Abraham Iqbal, 16 Sep 2016 GC8, wrx, subaru, rexy, ej20 |
Tech: The basics →
General →
GC8 WRX Idle Hang and Dipping with idle hunt!Started by Abraham Iqbal, 11 Sep 2016 gc8, idle, tps, iacv |
Model Specific →
Liberty / Legacy / Outback →
Engine / Driveline →
Do any other subaru diff backs fit Gen2 Libertys/Legacys?Started by Maustead, 14 Jul 2015 legacy, GC8, diff back, exhaust and 2 more... |
Tech: The basics →
Single Turbo →
MAF replacementStarted by ThomasC, 05 May 2015 Mass, air, flow, gc8, wrx, MAF |
