Hi guys,
When I lift off the accelerator and the revs drop below roughly 2500, the whole car shudders and jolts. The only way to stop it, is to put the clutch in, change to a lower gear (so the revs become higher) or to go to neutral. This happens whether the car is cold or at running temperature. Does anyone know what could be causing this because I don't think its good for the car to be shuddering constantly.
2002 Subaru Liberty RX 2.5 Sedan
Cheers guys
I'm going with a driveline issue. Broken mounting or similar.
Things like coils, plugs, leads etc are usually at fault when the engine is under load. (this is when a greater volume of fuel is delivered, thus stressing the ignition system)
Forget cleaning your MAF, you don't have one.
The n/a 2.5 uses a 'speed density' engine management system, therefore it uses a MAP, not a MAF.
MAP= Manifold Absolute Pressure sensor
(measures the air pressure in the inlet manifold and compares it to atmospheric pressure, combined with the Inlet Air Temp sensor it allows the ECU to calculate air flow into the engine)
MAF = Mass Air Flow sensor
(measures the volume and temp of incoming air to calculate air flow into the engine)
Sorry for the detail, but I see this mistake often made and some days it bugs me more than others.
Today is one of those days.
