Hi all,
the car is a 1995 Subaru BG5 - twin turbo ej20 - Liberty GT Sedan
Problem: No hot air out of cabin vents. Bottom (lower) radiator hose doesn't warm up.
Notable fact: The car does not overheat when driven.
What I did already:
1. I checked the thermostat, replaced it with a genuine Subaru part. Boiled it prior to installing it, it works fine.
2. Removed radiator and flushed it. It doesn't seem to be clogged, the flow seems to be 1:1 - as far as I was able to observe. I took it out, pumped water to the top opening and the water came out nicely from the bottom opening.
3. Replaced radiator cap - new genuine part.
4. Cooling system pressure test revealed no leaks.
I have not seen the passenger side radiator fan come on - ever. Only the driver side fan comes on once the car heats up - and then stays on infinitely. But there is no hot air coming out of the vents.
I believe I bled the cooling system properly - I raised the front of the car up. Filled through the radiator filler all the way to full, then put on the cap.
I then filled through turbo tank, started the engine, put heating temperature inside to max, A/C off, fan to min...
I massaged both the top and bottom radiator hoses until there were no more bubbles coming out. And filled the turbo tank as required.
But still - no hot air inside the vents, and the bottom radiator hose doesn't get warm. I heard some other members of the forum saying it's meant to be cooler than the top hose. I agree, but the top radiator hose is boiling hot, and the bottom is dead cold. The bottom radiator hose should be warmer - much warmer that this. (engine working temperature)
Also the driver's side of the radiator is boiling hot, and the radiator cap itself is very cool.
I know, this could be something as simple as clogged heating core - it wouldn't bother me - but how can I be sure? The lower radiator hose is what worries me - along with the fan that only comes on and never turns off.
At this point I am open to hearing all the opinions - what else should I try? Also please feel free to comment on something as obvious as "that's normal Subaru behavior", I've only had the car for a very short time, and it's all very new to me.
Thank you in advance for all your input.
