Looking at getting DBA T2 rotors for the Outback but need a knowledgeable person to guide me on what I can fit with stock calipers. I have a feeling 294mm and 290mm diameter are going to be too big. Will I have to go for around 170mm?
2001 Outback brake options?
Posted 02 January 2016 - 11:23 PM
If you are leaving the calipers, then the OEM diameter is the only option.
TBH if you use the money for the rotors towards a set of GenIV GT-B or 30RB 316mm calipers and rotors, you will be better off.
Posted 02 January 2016 - 11:36 PM
Don't need *dogbones for them?
Edited by ChrisLovell, 02 January 2016 - 11:36 PM.
Posted 03 January 2016 - 12:06 AM
No dogbones needed for the front brakes (316mm) but you do need 17inch rims.
Posted 03 January 2016 - 09:24 AM
IIRC your stock brakes rotors are 277mm and 266mm.?
Posted 03 January 2016 - 10:00 AM
A mate has a set of GTB calipers he's wanting to sell. I can ask him cost if your interested.
The rear rotors will be 290 solid, standard 4 cyl outback.
Posted 03 January 2016 - 10:54 AM
OEM diameter is 294/290 mm.
Just be careful - rears are 10mm solid, not 18mm ventilated like the B4 (Though I'm assuming that the rear calipers are different -- maybe they're not and you can run 18mm ventilated ?).
Posted 03 January 2016 - 11:02 AM
The rear vented disc type caliper (B4/H6) is different to the solid type caliper.
