EJ20 - EJ25 Engine Swap/Manifold Swap
Posted 29 March 2016 - 09:59 PM
Posted 29 March 2016 - 10:03 PM
Block has nothing to do with the intake manifold. If youre reusing the heads itll work just fine
Posted 29 March 2016 - 10:09 PM
Ok. The problem i have is a pretty long one. I cooked the ej20. Kinda. Blew the gaskets and the heads will probably need to be machined.
To replace the gaskets and machine the heads. the cost was close to 2.5k. The engine had just done over 200k. I thought it would be heaps easier. if i could get a newish engine. Some bad advice given to me. apparently you can't just swap an ej20 with an ej25 very simply. (Without changing the ECU and Loom). I managed to pickup an EJ25 with only 30k's on the clock. for $2000.
Ive heard from a subaru guru that just replacing the intake manifold should do the trick. I just don't know if the EJ20 manifold would fit on to the ej25 block. And i can't test fit it without voiding the new engine warranty/ ability to a refund.
Posted 29 March 2016 - 10:12 PM
The only thing you need to be careful with is cam trigger wheels and things like that
I can't see any of that stuff being different
Posted 29 March 2016 - 10:17 PM
Manifold should just drop on
Without replacing or using the existing heads?
Posted 29 March 2016 - 10:18 PM
Posted 29 March 2016 - 10:23 PM
Using the 2.5 heads
It sounds too good to be true haha. So many people reckon otherwise. The engines are basically the same apart from the bore size. Amiright? If you or know someone who has done this. i guess ill just risk not getting a refund on the engine. Id much rather the EJ25 over the EJ20. Thanks for your help BTW. much appreciated.
Posted 29 March 2016 - 10:24 PM
Correct. You might run into issues with the ECU though. The earlier ECUS were able to handle this swap but im not so sure about a newer one
Posted 29 March 2016 - 10:30 PM
Couldn't i just get an ej25 ECU from the wreckers if the one i have isn't self learning?
Posted 29 March 2016 - 10:42 PM
If the wiring is the same you could. Could have issues with immobilisers then
Posted 29 March 2016 - 11:15 PM
Posted 29 March 2016 - 11:17 PM
Technically speaking will the ej20 manifold fit the ej25? Without any modifications?
most likely yes
Posted 30 March 2016 - 06:48 AM
I have mild concerns about fueling. Are the injectors the same size for ej20 vs 25? They aren't in the turbo models. Therefore, will your ECU be able to provide enough fuel for the ej25 within its learning parameter boundaries, or will it be lean knock city? I don't know, but if want to know before all the effort of potting in a different motor.
What year and model is the ej25 from?
Was the 06 also available with an ej25? If it wasn't, you'll land yourself an $800 engineering bill before you can register the motor change with RTA.
Posted 07 April 2016 - 06:22 PM
If all the parts are from the 06'-07' model range then all the ancillaries, heads, etc should bolt straight onto the 2.5lt block. Combustion chamber volume is smaller on the 2lt heads but not enough to be a problem. The 2.5lt ECU is mandatory and you must use what ever injectors that ECU was originally run with. The ECU need to be swapped by a Subaru service centre as they require re-coding. Other than that, it's a straight forward swap.
Posted 07 April 2016 - 07:26 PM
Probably would have been cheaper to just get the existing heads machined and thrown back in.
Posted 18 May 2016 - 08:45 AM
Hey guys,
I've just acquired a 1996 Impreza.
it is the EJ18 from the factory, but it now has an EJ25 in it.
it needs a blue slip and my question is, is this Legal under NSW road rules?
Also tagged with one or more of these keywords: EJ20, EJ25, SWAP, MANIFOLD
Model Specific →
BRZ →
Will a FA20 Trans bolt to a EJ25 short block.Started by TofuHussle, 17 Feb 2020 FA20 Trans, EJ25 |
Tech: The basics →
Naturally Aspirated →
EJ25D/EJ251/EJ253 oil pump sizeStarted by El_Freddo, 13 Feb 2018 Oil pump, ej25, ej25 oil pump and 3 more... |
Tech: The basics →
Engine tappingStarted by Kilst, 12 Jan 2017 ej20, tapping, noise |
Model Specific →
Forester →
Builds and Projects →
Tips on modding a 97' turbo FozStarted by Kahn McCall, 02 Jan 2017 forester, toaster, ej20, turbo and 3 more... |
Suby Club Community →
General Discussion →
Tips on modding a 97' turbo FozStarted by Kahn McCall, 02 Jan 2017 forester, 1997, turbo, foz, fozzy and 3 more... |
