hi guys got a standard hatch impreza 09 got a code for O2 bank 1 sensor 2
just want to know which one is it? ones 4 pin connector ones 6?
Posted 21 April 2016 - 09:19 PM
Posted 22 April 2016 - 01:53 PM
WHat was the actual code#
Posted 23 April 2016 - 11:38 AM
p0037 oxygen sensor heater control circuit, low bank 1 sensor 2
Posted 23 April 2016 - 01:58 PM
I've tried clearing the code off the scanner, light still stays on (engine light, traction control light, cruise light flashes)
any other method to reset ?
Posted 26 April 2016 - 11:28 AM
p0037 is the Rear O2 sensor which usually looks after CAT converter efficiency more than anything.
If the code won't clear then I'd be looking at the physical wiring and connectors first,
What sort of scanner do you have?
Will it clear codes with the engine running?
Do you have any exhaust mods?
Have you recently done anything under the car or in the engine bay?
Posted 01 May 2016 - 12:06 AM
yea it was the second sensor i checked the connection retried scanning an clearing worked this time
thanks
