Liberty b4 twin turbo my03 starting problem. Need help
Posted 14 May 2016 - 03:09 AM
https://youtu.be/FRD2nv2v_2g
Posted 14 May 2016 - 08:12 AM
I'd suspect fuel or spark.
Pull the fuel line from the tank/pump at the firewall and see if you get a good spray of fuel into a bucket when the ignition is on.
#3 Guest_KONG_*
Posted 14 May 2016 - 01:32 PM
Posted 14 May 2016 - 07:39 PM
Posted 14 May 2016 - 08:55 PM
there's your problem then.
Check the fuse first.. then getting voltage at the pump?
Could be your pump or controller has gone tits up.
Posted 14 May 2016 - 10:23 PM
#7 Guest_KONG_*
Posted 15 May 2016 - 03:29 AM
Posted 17 May 2016 - 11:14 AM
ok, maybe not the issue but
#1) don't rush the keys from Off to Start in any car
turn to ON, wait for the FP relay to click, or the gauge sweep in cars with a fancy dash then turn to START
#2) if you're not hearing the FP prime, then troubleshoot that circuit.
Fuses and relay first, then the wiring loom plug under the rear seat, or as mentioned Immobiliser.
Posted 17 May 2016 - 04:10 PM
If the fuel pump doesn't prime when you turn the key. And you've checked all fuses and relays (its the big round silver relay under the dash) and eliminated any immobilisers. As duncanm said, It can either be the fuel pump or the fuel pump controller.
I'd try another fuel pump, if it still doesn't go then move on to the fuel pump controller. I was lucky enough to borrow a fuel pump so I could test.
Worst case, its a wiring issue.
Posted 16 February 2017 - 09:00 PM
Posted 16 February 2017 - 09:44 PM
Id be double checking the battery. Swap a known good one or check with a multi meter. No an normal starter wont work. You need a start from a B4
Posted 16 February 2017 - 10:00 PM
Posted 16 February 2017 - 10:42 PM
I recently had a battery die but it still showed +12v on the multimeter and the battery check window was still showing it was okay. All windows, lights etc worked, car just wouldn't start.
Noticed battery was a bit swollen and emitting a stank. Chucked it and bought a new one, and blammo car started perfectly.
If it was the starter motor you wouldn't even get a click.
Posted 17 February 2017 - 09:22 AM
give the terminals a good wiggle, too. Often its as simple as a corroded or loose connection.
Posted 18 February 2017 - 08:33 AM
