I have been considering installing a manual switch on the dash wired to the main cooling fan and indication lights to tell when the cooling fans are operating. My only concern is will installing such a switch and indication lights play havoc with the ECU has anyone else ever attempted this.
Currently the ECU controls the radiator cooling fans I guess I would just like to have manual control over this instead of the ECU. Any Ideas
Radiator cooling fans manual switch with indicator lights
Posted 03 August 2016 - 08:27 AM
Posted 03 August 2016 - 10:40 AM
Posted 03 August 2016 - 11:22 AM
There's nothing to gain from this, unless perhaps you're building a drift car or drag car and want the fans running straight away (because you're about to mash the car).
Least shit way to do this as an override (retaining ECU behaviour when switched off) is to have your switch send 12v to the fan relay.
Take your LED feed from the same pin on the relay, so that your LED lights up regardless of the source of the power (ECU vs your switch).
Again, don't bother, this is 100% rice.
Also tagged with one or more of these keywords: cooling, radiator, fans, diy switch
Suby Club Community →
General Discussion →
Please help! EJ207 issue. *Very paranoid*Started by K.Tonic, 03 Oct 2016 Head gasket, overheating, ej207 and 2 more... |
Tech: The basics →
Twin Turbo →
Troubleshooting cooling systemStarted by podmak, 22 Nov 2015 cooling, coolant circulation and 4 more... |
Model Specific →
Liberty / Legacy / Outback →
Gen 3 wagon radiators same as sedans?.Started by dylanfh, 27 Jul 2015 radiator, gen3, wagon, 2000, 2.5 |
Tech: The basics →
General →
Poll
1.1 bar vs 1.3 bar radiator capStarted by Liberty, 16 Sep 2013 sti, radiator, cap, 1.3 bar and 1 more... |
