B4 2001 Liberty TT problems
Posted 08 August 2016 - 07:44 PM
Posted 08 August 2016 - 08:01 PM
Hello Hylo43. Plenty of info on this site regarding the TT when you search. You might also want to first introduce yourself in the "Introductions" section of this forum......hopefully you will sort this quickly and be able to enjoy your new ride.
Posted 08 August 2016 - 08:38 PM
Smoke out the back? Was it coming out the exhaust, or oil on hot exhaust/dump/header/turbo or something?
Posted 09 August 2016 - 10:30 AM
First find out where she's burning oil and is there any left in the sump.
Yeah still oil in the sump. Smoke from engine bay as if burning off exhaust or manifold. Initial sight of burning coming up between intercooler and manifold .
Posted 09 August 2016 - 10:57 AM
check out the IACV (intake air control valve) - up above the secondary (driver's side) turbo - which switches the secondary turbo outlet to the TMIC.
Blowby collecting in the TMIC often ends up at that valve and sometimes drips out -- worth pulling the TMIC and giving it a good flush with petrol anyway.
If that's the case - also pull all the vac lines coming from around that area (I think there's three on the secondary TMIC inlet) clean them all, and any solenoids in the BBOD, with some carb cleaner or similar.
Posted 13 October 2016 - 04:26 PM
Car has also developed a grinding sound and what sounds like a wastegate issue begging at around 2300rpm..
Truly clueless..
Posted 14 October 2016 - 08:33 AM
Sorry to say, but sounds like the primary turbo is blown.
Posted 27 October 2016 - 11:45 AM
Posted 27 October 2016 - 03:43 PM
Oooh that looks nasty.....
Posted 27 October 2016 - 04:47 PM
is that like... no compressor wheel ?
I wonder where all those metal shavings went... oops.
Posted 27 October 2016 - 07:06 PM
Posted 27 October 2016 - 08:58 PM
