Engine cut under acceleration, please help
B4 engine cut
14 replies to this topic
#1 mousham
mousham
  • 12 posts
  • Interests:B4's, Beer, Buegs
Posted 12 August 2016 - 08:54 PM
Hey guys, reckon you could help me out, I'm having some super frustrating issues with my b4, its engine cutting if i use more than quarter/third throttle at any rpm, even sometimes before boost kicks in so I'm thinking it's not over boosting.
Here's a video i recorded today to show ya
basically what happens is the engine cuts instantly and engine breaks until i ease off the pedal, then right back into full acceleration because it holds boost while engine breaking. Either that or it jerks uncontrollably until i clutch save it. The cars very dangerous to drive in this condition and it's put me at risk while overtaking before . engine cut seems to happen way easier the higher the car is in gear.
While i had the black plug under the dash connected to read my ODB codes i took the car for a drive and there was only one engine cut in second gear in like 10 mins of driving with a lot of full throttle, so now I'm really confused.
if it helps this is the vac line setup I'm using: Attached File  1cc1a3ed.jpg   157.3KB   9 downloads
Here are the error codes I've got
P1237
P1239
P1235
P0031
P1249
P0249
P0250
P1247
and its not the fuel pumps fault, I just installed a walbro 255, reset the ecu, still same codes as above.
Help would be greatly appreciated, i just want my suby to drive properly for once :'(
#2 mousham
mousham
  • 12 posts
Posted 12 August 2016 - 09:24 PM
oh yea btw im using 0.8mm and 2mm welding tips as pill restrictors (they're a dollar each so why not), theyre significantly longer than pill restrictors, probabaly 5 times longer, could this be a possible cause? Attached File  IMG_20160731_162322.jpg   219.55KB   7 downloads
#3 duncanm
duncanm
    wha' who ?
  • 2,010 posts
Posted 13 August 2016 - 08:30 AM
Is it an electrical cut (really sudden, puffs of black smoke afterwards due to overfuelling) or a fuel cut?
Does it make a difference if you're going up or downhill - or over bumps etc? - may indicate loose wire somewhere.
I don't understand what's going on with line 10 in your diagram - shouldn't that go to intake ? I think the one you have marked '10' on the boost side of the solenoid is actually '23' - do you have a boost gauge and know what boost you're hitting?
The restrictions you used will be different to the Subi pills, but unlikely to be causing these issues.
#4 Reevesy
Reevesy
    Adriano
  • 1,597 posts
Posted 13 August 2016 - 09:01 AM
Sounds a lot like a spark breakdown problem. Check plugs and coilpacks
Sent from my SM-G900I using Tapatalk
#5 mousham
mousham
  • 12 posts
Posted 13 August 2016 - 03:33 PM
yea there's black smoke
it's so much worse up hill
my bad about the diagram its actually like this Attached File  1cc1a3ed.jpg   155.7KB   4 downloads
#6 mousham
mousham
  • 12 posts
Posted 13 August 2016 - 03:36 PM
the spark plugs are only like 3 months old, no idea how the coils r going tho, what would i check for with the coils?
#7 duncanm
duncanm
    wha' who ?
  • 2,010 posts
Posted 13 August 2016 - 04:10 PM
ok - so black smoke means over-fuelling, due to lack of spark or boost/fuel mismatch. I think subaru has fuel cut on overboost (not spark) - so that probably rules that out.
I don't think it'll be a coil pack or spark plug -- that'd just take out one cylinder.
Checked you haven't got an intermittent boost leak that flaps open on boost? Engine would still run, but power would drop way down (so that doesn't really match the symptoms).
It sounds like some sort of fundamental electrical problem -- ground or power or ECU connections intermittent.. try undoing and re-torquing all the ground straps in the engine bay, and check your ECU plugs (give them a squirt of contact cleaner) -- do the same with all the important engine sensors like MAF plug, etc. Check none of the wiring looms are pinched or damaged at the firewall grommets and around the engine bay.
(diagram now looks fine, I think, btw).
#8 duncanm
duncanm
    wha' who ?
  • 2,010 posts
Posted 13 August 2016 - 04:19 PM
Definitely something electrical -- and I'm guessing wiring/power to ECU.
Many of those codes are "XXXX solenoid LOW"
Check the whole engine harness back to the ECU and the power wiring to the ECU.
#9 mousham
mousham
  • 12 posts
Posted 13 August 2016 - 04:42 PM
ill do my best but i should probably mention i have no experience w auto electronics. its sesh oclock rn so ill call it a day for today, ill keep u posted tomorrow when i get under the bonnet. cheers mate
#10 Guest_KONG_*
Posted 14 August 2016 - 03:35 AM
Did all this start after you installed the Walbro? The first 3 codes are all fuel pump circuit related.
Check your front O2 sensor asap, if it is OK you can rule out the P0031 as it will most likely be from the first 3 codes & a result of the over fueling.
The last 4 codes are wastegate control related.
#11 mousham
mousham
  • 12 posts
Posted 14 August 2016 - 12:11 PM
Hey and nah I got the same errors like a week before i installed the walbro, it made no effect to the errors, I'll give the 02 sensor a check real soon, what should I look for on the o2 sensor?
#12 duncanm
duncanm
    wha' who ?
  • 2,010 posts
Posted 14 August 2016 - 01:45 PM
I reckon the codes themselves don't indicate anything other than something more common to them all is going wrong.
The codes are flagging just about every solenoid or sensor you have.
#13 duncanm
duncanm
    wha' who ?
  • 2,010 posts
Posted 14 August 2016 - 03:33 PM
Ok - dug around the FSM I have
P1237 ECV +ve pressure solenoid LOW
P1239 ECV -ve pressure solenoid LOW
P1235 IACV solenoid LOW
P0031 O2 heater circuit LOW
P1249 Relief Valve ciruit 2 solenoid LOW
P0249 Wastegate solenoid B LOW
P0250 Wastegate solenoid B HIGH
P1247 Relief Valve solenoid LOW
ALL of which (apart from P0250) suggest that these solenoids aren't getting power (and the ECU is sensing the output is stuck LOW).
All these ciruits run off SBF-5 through the main relay.
Check SBF-5 in the main fuse box in the engine compartment.
Plug your diagnostic connectors together and check that your ECV is cycling and your solenoids are clicking.
If not -- then suspect the power to these solenoids. There should be 12V on one pin of each solenoid when IGN is on.
#14 mousham
mousham
  • 12 posts
Posted 14 August 2016 - 05:25 PM
Alright so here's what happened just then. Put the car in diagnostic mode and noticed there was no clicking from the bbod, the bloody power unplugged itself slightly. Phew that's such a relief. I only have 2 codes now P0250 and p0031. Problem is I'm getting engine cuts still but only at full throttle at around 4k to 5k although there was one cut at close to 7k w full throttle
#15 mousham
mousham
  • 12 posts
Posted 14 August 2016 - 06:04 PM
I bet the o2 sensor is fkd bcos the map sensor was disconnected fuuu :'( could someone please link me a new denso 22641 AA090 I don't wanna accidentally buy a fake or something
#16 podmak
podmak
  • 104 posts
Posted 10 October 2016 - 10:16 PM
Kudos duncanm!
Also tagged with one or more of these keywords: B4, engine cut
