Hi Guys,
I've been having an ongoing issue with my GC8 - when driving the car is fine but when i come to a stop, the issues begin! it starts off with the idle hanging around 1100 (idle speed is adjusted correctly), this then drops to around 800 and then drops to around 600 and picks up by idle hunting! this normally happens with the clutch in idling at lights and while stopped
I have changed MANY things so far and tested crap loads of different things;
- MAF changed twice
- O2 sensor changed once
- IACV cleaned and then a 2nd hand replacement was sourced cleaned and installed
- Knock sensor replaced - this was faulty at some stage - genuine quality part
- checked for vac leaks and boost leaks none found
- coil pack replaced with OEM unit
- new spark plugs gapped and installed
- ECU reset MULTIPLE TIMES
- entire throttle body replaced and TPS replaced at the same time
- accel cable adjusted correctly
- coolant system bled multiple times
Is there anything i may have missed?
- Is there a throttle reset procedure for this car? i have looked at a few other subaru procedures for this and no change
- Is it possible the neutral position sensor can cause this issue? even though i dont have to have my car in neutral to start it? im not sure on this one
- is it possible the crank and or cam sensor could cause this issue?
my GC8 is a MY98 Early build (V4 WX) with the older style IACV btw
I'm pretty much at my wits end with this issue.
and help would be great
