Hey.
I've fitted a dw65c (9-652-1008) to my RevC RSK, and changed the fuel filter at the same time.
On reassembly, I reconnected the fuel pump relay next to the driver's fuse box, reconnected the battery, and the pump primes nicely. Primed about five times then started. Engine started perfectly. But, it runs for about 30sec (ish, haven't timed it) then rpm wanders and engine stalls shortly after.
I thought the sock might not have been installed properly and could have been pressing up against the bottom of the tank. Removed the whole lot again, refitted the sock all the way to the base, checked the pump was seated properly, and reinstalled.
Same problem. Just started the engine again - car runs fine when the pump runs, but it's the pump that stops around 30sec and stalls the engine.
Does the ECU need to relearn something for the faster pump? Have I busted the pump controller somehow?
Any pointers would be solid gold. Thanks guys.
Mark
