Engine swap between Subaru rx hatch 2.0L 1998 to a Subaru rx sedan 2.0L 2002
Started by nate96, Feb 16 2017 07:02 PM
4 replies to this topic
Posted 16 February 2017 - 07:02 PM
i wanna put a 1998 rx suby with a working engine and transfer to my 2002 rx suby
Posted 16 February 2017 - 07:34 PM
So a 98 engine in your 2002 rx? No chance. Wiring is vastly different and just about everything other than the bare engine block. Besides putting an engine older than the car itself is illegal from an emissions standpoint.
Posted 17 February 2017 - 03:28 PM
What's wrong with your engine?
If it's a an issue within the shortblock then you might get away with just swapping that.
Probably better off going for some thing newer or rebuilding what you have.
Posted 17 February 2017 - 09:10 PM
May as well do a halfcut turbo conversion for that amount of effort...
Posted 17 February 2017 - 11:32 PM
What's the issues with the engine?
All you can really swap is the '98 block and heads onto the '02 intake manifold to make it work.
If your issue is a sensor you won't solve it this way! If you've got low compression or blow by issues you'll be fine.
As for old engine into newer car it's about the emissions, not the block per sae.
