B4 Front Mount (Many Pics)
Posted 06 July 2009 - 09:40 PM
of cutting of the bar. We did not use the cooler that is in there kit, just the piping. Although because the cooler was not the exact size that they designed the kit with we needed to do some modding on the cold side of cooler.
I suggest that anyone who wants to do this should not buy the cooler they supply as i'm sure there would be no chance of keeping the crash bar, just make sure the widths are the same as there. As you can see it is still possible to keep the crash bar if you get a shorter cooler.
Engine Bay with the Interwarmer removed
First section of the piping as it comes off the two turbos
Cooler with mounts bolted onto the top.
Half mutilated crash bar, because it's a short cooler, only the bottom of the bar had to be cut out.
Atleast it doesn't look defectable.
This is the back of the front bar, even after this there was heaps more to cut out. There is no chance at all
that the driving lights could be kept.
Cooler mounted to the underside of crash bar.
Pod mounted in guard alongside hot pipe onto cooler, freed up room in the engine bay for coolant overflow
Overlow bottle in place of stock air box. Pod and hot pipe go into each hole in the guard.
Hot and cold pipes connected to cooler
This is what happens when you get the wrong size cooler. Quick trip to bunnings plumbing section. (this pipe now changed to a silicon joiner)
Cold pipe coming up infront of Cam belt cover, taking the place of the coolant bottle.
Temporary Blow off valve (now replaced)
All Done up
The finished product.
I've noticed no real difference in lag or VOD. A maybe a tad more power, could be a placebo effect though.
The biggest difference is heat soak, no power drop even after a lot of boosting. Summer will be the real test though.
If you do it make sure all clamps are done up really tight, it's not good fun playing mechanics on the side of the road.
Posted 06 July 2009 - 09:50 PM
Posted 06 July 2009 - 09:58 PM
Posted 06 July 2009 - 10:02 PM
Posted 06 July 2009 - 10:43 PM
Posted 06 July 2009 - 11:05 PM
Posted 07 July 2009 - 07:30 AM
Posted 07 July 2009 - 08:02 AM
Looks good, Congrats on giving it a go.
But i would try and invert the core and try and run the piping just under the headlights (like the Rs's) So you an still have your foggies
Good luck to anyone who tries to invert it. Pics do not do justice to how little amount of room there is at the front of a B4. Also depends on how defectable you want your car to be.
The lights are just bling anyway, not useful for anything. It's much more beneficial to have a FMIC IMO.
Looks very tuff mate!
Thats one dirty engine bay! Clean asap!
Why? There no underbody cover anymore, it'll just get dirty again
I'm one of those people who dosn't care to much about under the bonnet, once shut you cant see it anyway.
Posted 07 July 2009 - 08:22 AM
Posted 07 July 2009 - 10:00 AM
Posted 07 July 2009 - 10:10 AM
Posted 07 July 2009 - 10:11 AM
Posted 07 July 2009 - 10:12 AM
the big question is... does it flutter!!! haha
Probably did when he had that rubber thing where the BOV is ment to go
Posted 07 July 2009 - 11:48 AM
Interesting that you can see so much of the piping in the front air damm.
with my install you see a lot less:
Posted 07 July 2009 - 12:45 PM
Oh yeah, hard work not laughing at myself on every gear change though
Also went like poo, no boost after gear changes.
Looks tops mate
Inverting the core looks like it could be quite easy to do, few silicon bends and cutting the piping.
I'm not a fan of seeing the inlet and outlets of the core and the silicon joins. Maybe the core could sit about 2" lower, it would hide the joins and foggies might be able to be used.
Simple, i could not be even an inch lower, it would then be lowest part of the car.
Looks good.
Completely different bar though, had no choice but to take that much out.
Posted 07 July 2009 - 05:43 PM
Mate i know EXACTLY what you mean, i installed this exact kit (except with the supplied cooler) on sunday, me and a mate spent 10 hours putting it in, i am going to get rid of the cooler that came with the kit and get a shorter one like yours cause i cant even run a crash bar the way it is now. Can i ask what the exact measurements of your cooler are ? and where you bought it from ?
Are you going to get the BOV flange re welded so its pointing down instead of the stupid angle its on now ? with the bov im now running it hits on the bonnet cause of the pipes direction.
Did you cut the bar all yourself ? We attacked mine with the angle grinder haha, theres bugger all left of it now! im going to have to take it to a body shop to get it smoothed out, im also getting them to cut out the fog light mounts completly.
Posted 07 July 2009 - 08:51 PM
Posted 07 July 2009 - 09:37 PM
Posted 07 July 2009 - 09:52 PM
Posted 08 July 2009 - 08:01 AM
Na we have already changed that, two 90' copper bends welded together to face the othere way so i am still using the
factory BOV. I'll put up a pic soon.
Yeah we cut/trimmed everything, that is a large reason why it took so long.
i hope you cut out the crashbar where it was covering the core, and cut the top of the mouth of the bar (where you cant see)
so that the entire core gets airflow, there are a lot of fmic installs around that dont work properly due to blocked cores
We only cut out the bottom of the crash bar. The cooler is not actually visible when looking under the bonnet, i don't think it will really effect flow, the radiator works fine when it's not all exposed. The fan during summer will also suck air through the top.
