Hi,
I just received my Subaru B4 Rev D and it is not making boost.
1. I have read through the Twin Turbo guide and took off and inspected the TMIC (very challenging to put back on). Everything looked okay. The IACV was closed but freely movable manually. I then cleaned and replaced the lines in the BBOD making sure to note to replace the restrictor pill in line 2. I put everything back together and I still am not making any primary or secondary boost.
My boost gauge shows vacuum of 20+ but whenever I'm driving it won't go past 0.
2. I don't have any CEL or stored codes as the black connectors once plugged in shows a steady flashing CEL. I plugged in the green connectors and while i hear clicking and fans going on/off, I do not see the either primary or secondary actuators arms moving. Would that be part of the problem?
Can anyone point me in the right direction how to diagnose this problem? Thank you!
