Burning rubber smell after lca replacement
Posted 31 May 2017 - 05:51 PM
A wheel alignment was also conducted but i can't see any signs of tyre rub etc. Any help would be appreciated!
Posted 31 May 2017 - 06:43 PM
Had a similar problem with my RX-7 when I had a track suspension kit fitted to it (actually raised the height of it as the original springs had sagged that much) turned out to be the inside wall of a tyre rubbing on a suspension component. Take both the tyres off of the end of the car that's had the suspension work and check the inside side wall of each tyre looking for a gouge line that's at constant radius in the tyre. In my case the Rotary experts immediately requested my car back and "adjusted" the suspension of my car.
Posted 01 June 2017 - 08:44 AM
