Boost leak??
Posted 27 June 2017 - 09:25 AM
Posted 27 June 2017 - 09:32 PM
The secondary will not kick in at those revs m8.
I get a sound like that between 2 and 2.5k rpm, almost like the exhaust is hitting the floor.
Posted 28 June 2017 - 08:47 AM
Posted 28 June 2017 - 06:20 PM
Does it happen in all gears or only when you change from 1st to 2nd ??
Posted 28 June 2017 - 06:35 PM
#6 Guest_KONG_*
Posted 28 June 2017 - 11:31 PM
Would like to see that video
Posted 29 June 2017 - 05:39 PM
Posted 29 June 2017 - 08:54 PM
Posted 30 June 2017 - 06:33 AM
#11 Guest_KONG_*
Posted 30 June 2017 - 06:39 AM
Have you had the inter cooler off recently?
Have a good look at the pipes to see if they are on properly and check the hose clamps are done up real tight.
If that doesn't stop the noise you may have to remove the IC and inspect them further.
Posted 30 June 2017 - 12:22 PM
Posted 17 July 2017 - 05:36 PM
#14 Guest_KONG_*
Posted 18 July 2017 - 09:41 AM
It's a good sign that you're getting boost above 6k rpm
Replacing that secondary pipe should be a priority. It may not be the exact issue but the best scenario is that it is still leaking and the differential pressure sensor is not seeing enough boost for the ECU activate changeover.
It's important to eliminate this from the equation & It's best not to get too far ahead of yourself with diagnosing your problem until you are 100% sure that pipe is sealing.
But in the mean time, you should be individually checking all your vac lines for cracks/splits/holes and be reading up on how to put your car in diagnostic mode using the green plugs under the steering column so you can check some of the TT solenoids and valves are working.
Do you have a check engine light lit up on your cluster?
When you had the IC off did you remove the vac line to the IACV on the secondary hard IC pipe and did it make an audible sucking noise?
Posted 19 July 2017 - 08:03 AM
