Hey all, know its probably been said before a number of times but hey. So I bought a 99 Impreza WRX off a couple of panel beaters and they had already pulled the engine out and basically apart. So i have 2 questions, 1st is there anywhere I can get a repair book like a Haynes mechanical or something of similarity (as Repco and the sort said there isn't a Haynes one)? And 2nd while the engine is out and basically apart what is the best way to clean it all off and get it ready for the overhaul I am about to in-bark on?
Best way to clean the engine while its out and apart?
Posted 30 June 2017 - 07:25 PM
Posted 01 July 2017 - 07:07 PM
If you're DIYing, I clean my engine bits in petrol. Not good for your skin and definitely do not smoke or have the wood heater going in the shed!
I tend to try and give everything a good degreaser and gerni treatment before pulling it all apart.
Physical scrubbing will be needed for high grime areas/bits
Spraying WD40 all over the bits and leaving them to soak over night can help too.
If you're getting work done at engine shops you can ask to have your parts cleaned - also a good time to paint if you're doing this. Shops will appreciate some cleaning work prior to dropping off of your parts
I'm sure there's many ways to skin a cat too
Posted 03 July 2017 - 01:50 PM
