Cyl. 3 and 4 not firing
Posted 29 August 2017 - 06:33 PM
Any thoughts would be appreciated
Posted 29 August 2017 - 07:17 PM
Then decided to swap 2 and 4 injectors and what do you know the problem went from cylinder 4 to cylinder 2.
Anyone got a cheap set of working yellow tops?
Posted 29 August 2017 - 10:25 PM
sure its the injectors and not the electrics?
Test them on the bench with a battery.
I'd be checking continuity from the injector plugs back to the ECU, too.
Posted 30 August 2017 - 06:21 PM
Posted 11 September 2017 - 11:03 PM
Phoned the bloke who cleaned and flow tested them for me, suggested supplying each one with battery voltage and tapping them with a screwdriver because they may be a bit sticky. So did that now it runs perfect. May have just been sticky from sitting around for a while, lucky I didn't order a new set lol
Very common with side feeds that have sat for a bit.
