2002 B4 liberty, ej25t engine conversion from 2012 wrx
Posted 28 September 2017 - 10:16 AM
I can also get my hands on a wrecked 2012 wrx with low k's cheap.
Is there anything that will stop me from doing a engine/turbo and running gear conversion to the b4??
Thanks in advance..
Sent from my SM-G925I using Tapatalk
Posted 28 September 2017 - 10:42 AM
The wiring will be the main one. Should be able to swap your manifold onto the WRX engine and do a single turbo conversion. But your ecu will be expecting twins and 2L not 2.5
Posted 28 September 2017 - 12:47 PM
nothing will stop you -- but there are a bunch of things to consider to make the path as easy as possible.
2012 will be CANbus -- run away from that ECU and electrics, cos you'll probably never get it going. Things like the CAN speed sensor will screw you up.
Three options:
1/ Drop the whole thing in then look at rewiring with an aftermarket ECU
2/ as above, put your B4 intake manifold (plus whatever sensors are different, like cam and crank) on it and get the B4 ECU retuned for the lower CR (?) and single turb.
3/ just swap the longblock (? not sure if this is doable).
2 is probably best.
When you say 'cheap' - you can pick up a JDM TT front cut for a couple of grand, or a new 207 longblock for similar $$
Posted 01 October 2017 - 05:05 AM
I found an easy solution.nothing will stop you -- but there are a bunch of things to consider to make the path as easy as possible.
Three options:
2 is probably best.
http://agtengineerin....au/canbus.html
This guy reckons his canbus emulator will sort me out.
What do you think, is this canbus emulator a game changer or what?
Three options:
2 is probably best.
Posted 01 October 2017 - 07:29 AM
certainly looks like a neat solution to the CANbus problem, neat find.
