Whiteline Roll Centre/Bump Steer kit worth it?
Posted 06 November 2017 - 12:09 PM
I've got to change both steering rack bushes on my gen 3 wagon. Is it worth installing this kit from whiteline at the same time.
http://www.whiteline...t_number=KCA313
It's currently riding pretty low on BC Racing coilovers (scrubs front guards) and whiteline reckon their kit is essential for lowered cars.
I've got to replace rear lower control arm bushes too so thought I may aswell freshen the front end up a bit.
Posted 06 November 2017 - 12:16 PM
Don't really know if it makes a difference if you go really low (think it goes past the point of keeping the roll centre actually centred).
From memory, SuperPro's kit was cheaper.https://www.superpro...oductnr=TRC0002
Posted 06 November 2017 - 02:05 PM
It will help for sure.
Follow me on Insta: @brzdiy
Posted 06 November 2017 - 05:23 PM
Posted 09 November 2017 - 12:14 AM
If you haven't already, get some quotes from a few of your local Whiteline dealers, they might be able to do an even better price. Especially if you can get it at trade.
Repco for example, if you have a trade account or know someone that does, you should be able to get at least 30% off RRP.
Posted 10 November 2017 - 07:46 PM
20171110_194057.jpg 111.25KB 2 downloads
Will report back tomorrow after install
Posted 11 November 2017 - 08:03 PM
Personally i think the kit is definitely worth the money. Coupled with their lower control arm castor bushes the front end feels so much more solid and responsive.
Steering input feels a little stiffer, but a hell of a lot shaper.
Posted 11 November 2017 - 09:34 PM
Good stuff, did you end up getting all the gear from CMA? Did you get the comfort ALK (75 duro)[KCA361]?
Posted 11 November 2017 - 10:22 PM
Posted 20 November 2017 - 11:10 AM
I think you meant KCA319A (85 duro). How are you finding the comfort level of these so far?
Are they much harsher in terms of NVH than stock? I know it's probably difficult to compare to the worn stock bushings.
Posted 20 November 2017 - 02:34 PM
Thats is compared to two knocking and split originals though
One thing I noticed is that they had the bushes labelled round the wrong way.
Posted 20 November 2017 - 06:19 PM
Yeah fair enough, mine are the same. Pretty horrible and well overdue..
That's interesting about the labelling. Either labelled from the wrong perspective or just a flat out mistake I guess.
How about in terms of noise? Have you noticed any squeaking at all so far? Did you just use the grease that came with them? I know some people seem to recommend using silicone based lube instead.
Cheers for the feedback!
Posted 20 November 2017 - 09:11 PM
Yeah just used the lithium sachet that came with them. I've always used lithium grease with poly bushes.
