I need help!
Been struggling with timing belt for days and no matter what I do it keeps messing with me..
So I am a rookie I have never done one before..
I have all camshafts and crank lined up perfect.. belt goes on fine..
Then I release the tensioner, I rotate the engine a few times and the left size cams are not lines up, so I rotate a few more times and they get further of the marks..
I dont understand what else to do if they are lined up to begin with why wont they stay lined up?
I have counted all the teeth between crank and cams, and between the side cams and everything is right.. what do I do?
08 impreza timing belt DOHC
Started by Hannah91, Apr 22 2018 02:31 PM
2 replies to this topic
Posted 22 April 2018 - 02:31 PM
Posted 22 April 2018 - 09:07 PM
The lines on the belt wont match up once you rotate the engine around. If the lines on the cams and crank line up its fine
Posted 23 April 2018 - 07:29 PM
No need to create two topics about the same subject too.
