So it's been ages since I've posted on here but anyway
Doing a 6 speed conversion to back up the ej207 single turbo conversion I have in the works.
So couple questions
1. what wiring needs to be spliced or re-pinned etc? I'm guessing the auto ecu needs to be tricked into thinking it's in neutral?
2. Will a wrx clutch master fit?
3. I'm guessing a 6 speed flywheel will bolt straight on?
I have the box, front drive shafts, tailshaft and shifter linkage already.
What else will I need
Thanks
Auto to 6 speed conversion
Started by 01OBK, Jun 19 2018 06:55 AM
1 reply to this topic
Posted 19 June 2018 - 06:55 AM
Posted 19 June 2018 - 08:51 AM
Youll have to bypass the auto inhibitor thing to make it think its in park to start it.
WRX master will work fine
6 speed flywheel will work fine if you have the 6 speed starter as well. Can use 5 speed clutch, flywheel and starter but for both options use the 6 speed clutch fork
