Hey peeps, I had a leaking rocker cover gasket so ended up replacing both sides along with the spark plugs while I was at it. All went well but upon restating the motor I have a check engine light on. Thinking it may have been something i did when checking for leaks. I started up without the air filter unit on so I could see if any oil leaked out.
Anyone know if this might be what has caused it? Or if it might be something else? Is there an easy way to clear it?
Thanks
Sent from my SM-G960F using Tapatalk
Help! Check engine light after plugs and gaskets
Started by B-4, Dec 11 2018 09:42 PM
3 replies to this topic
Posted 11 December 2018 - 09:42 PM
Posted 12 December 2018 - 11:24 AM
clear the code and see if it comes back?
As an aside - how was it replacing those with the engine in?
Posted 12 December 2018 - 12:06 PM
Yeh I don't have a reader at the moment, might need to pick one up.
It was an absolute pain in the ass! Wouldn't attempt it with the covers on but as I had them off it gave a little more clearance. Not a fun job though!
Posted 12 December 2018 - 12:25 PM
Will the code not clear with a battery disconnect for a certain period of time? Otherwise I believe there is some kind of ignition sequence you can perform to clear codes. Not sure if it is applicable for the B4 though.
