Hey guy's, having a oil leak issue after replacing timing belt/oil pump
After doing job the oil pump was leaking so removed everything again and re sealed oil pump thoroughly with new o ring and new crank seal
Put it all back together and still have oil leakage from bottom of oil pump, seems to be leaking out both outer edges of pump at the bottom
I'm not sure what's going on?
Any input would be appreciated
Thanks
Helllpppp!! Oil pump leak
Started by Chaapppppp, Dec 17 2018 02:59 PM
3 replies to this topic
Posted 17 December 2018 - 02:59 PM
Posted 18 December 2018 - 08:44 PM
All bolts correctly torqued up? It’s very easy to over torque these without using a small torque wrench (something I’m yet to get). No fine cracks at any of the mounting bolts?
Try removing the cam covers and running the engine to see if you can pinpoint where the leak is from.
Also, all mating surfaces cleaned up and prepped with a white spirit such as metho?
What sealant did you use? There’s no mention of this in your post. Most would use three bond, I think I used some sort of high torque silicone for this application before I learned of the three bond stuff.
All the best with it.
Posted 30 December 2018 - 11:10 AM
All sorted
Used permitex the right stuff sealant and made sure not to over torque bolts as well i primed oil pump before starting.
Thanks for your advice dude
Sent from my M5s using Tapatalk
Posted 30 December 2018 - 02:12 PM
Awesome! I’m glad it was a “simple” fix!
