Fuchs Oil Pricing
alexGT 18 Sep 2009
For those who were interested. I can also get 5w40 (might be a bit more expensive) and 15w40. The 10w40 is recommended for all 2.0litre turbo and 2.5 non turbo models. I'm pretty sure subaru 2.5 litre motors run on 5w30 (can also get this). The gearbox oil is for all subaru manual tx.
5L 10w40 SuperGTO Synthetic = $39
20L 10w40 SuperGTO Synthetic = $152
5L TITAN GEAR SAE 75W-90 (All Subaru 5speeds) = $42
Motor Oil info:
TITAN
SUPER GTO
SAE 10W-40
• Technically advanced lubricant that utilises molecularly converted oils to provide increased high temperature performance, engine cleanliness & protection.
• Developed using Fuchs Super GTO MC Synthese Technology
• Specifically designed to lower fuel consumption and oil usage.
Gearbox oil info:
TITAN
GEAR
SAE 75W-90
• Semi-synthetic automotive transmission lubricant.
• Outstanding wear protection against wear even in the harshest conditions.
• Reduces foaming even at high road speeds.
• Excellent compatibility with differential shaft oil seals.
• Reduces differential ‘whining’ (with or without limited slip) even after long full throttle operation.
Motor Oil info:
TITAN
SUPER GTO
SAE 10W-40
Gearbox oil info:
TITAN
GEAR
SAE 75W-90
alexGT 18 Sep 2009
he is giving me 4x 5l bottles for same price as a drum. bottles are easier.
alexGT 20 Sep 2009
hey alex how would i pick them up if i order some
shane
next cruise if you like mate.
Can this be an on-going thing Alex, or is it a once off?
anytime you want dylan.
alexGT 20 Sep 2009
my bad, read the above in the cat for the supersyn, 5w40. if you want anything else from fuchs range let me know ill grab a price...
Alex 21 Sep 2009
Where can you get this stuff? Havent seen it in the shops...
Read the first post!
Alexxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx can get it!!
SAV84C 21 Sep 2009
i can get it any day of the week.
i should have specified.... I mean what shops usually sell this stuff?
How often u up in sydney alex? I'd be keen 2 get a bottle or 2 in the next week or 2... Maybe the next cruise or i can come down 2 the gong
