CAI and CEL light
Posted 06 February 2011 - 10:00 AM
I just fitted a CAI to my 2.5 GT.
Was all fine for a while until the engine light came om, cruise light started flashing
and car was locked into Sport Mode.
I didn't drive any different than it used to, and after a while the light went off again.
But last night it appeared yet again and is still on.
Anyone else experienced this or have any clue as to what the light would be
coming on for?
Posted 06 February 2011 - 10:25 AM
Get it scanned for codes.
Posted 06 February 2011 - 10:56 AM
Posted 06 February 2011 - 01:02 PM
are you using more / less fuel?
take out the AFM and spray with with some Contact Cleaner.. unless you poked your fingers in the thing, then it's done for good.
I had the Hyperflow in guard CAI, and never had that problem
Posted 06 February 2011 - 02:05 PM
#6 Guest_Jesse_*
Posted 06 February 2011 - 02:09 PM
Posted 06 February 2011 - 02:37 PM
go to dick smith or jaycar, and ask for contact cleaner.Na about the same amount of fuel as normal, what sort of contact cleaner would you suggest?
green aerosol can.
Posted 06 February 2011 - 03:13 PM
Check to make sure all the clamps and hoses are back on properly. You may have an airleak.
This may throw a code.
Air leak between AFM and throttle body.
Is it still running the OEM air filter?
If the car is running a little richer in cold air, it could be making the ECU scratch its head. Nothing to dramatic.
Posted 06 February 2011 - 03:30 PM
When you change to an aftermarket CAI this affects the housing of the AFM. Bigger pipe + your ecu not knowing about increase in volume of air = lean mixtures. You are going to need to plug in a scanner/tactrix cable and read the codes to know for sure...
This isn't something that the ECU learns it is a set table in the ECU. High RPMs + Bad scaling could lead to very rich or very lean AFR's. I'd get it checked before taking the car for a fang again!
Posted 06 February 2011 - 04:17 PM
Best stuff and proper for what you're after.. Or as Alex said go to jaycar though, the new dick smiths don't keep it anymore
If it's completely rooted, I have a spare one for you.
Don't be a tight ass and use brake cleaner!!
Posted 06 February 2011 - 04:30 PM
Posted 06 February 2011 - 04:41 PM
Posted 06 February 2011 - 04:44 PM
closed loop circuit is drawn from predefined tables.
Posted 06 February 2011 - 09:35 PM
How'd you know that that was my first thought?
Posted 06 February 2011 - 10:06 PM
Cause we must think alike..
Posted 06 February 2011 - 10:29 PM
NO!!!Isnt it everyones first thought
Posted 07 February 2011 - 11:09 AM
He said that because of the different rate and perhaps angle that air would be moving past the sensor that it may just be confused and turning on the CEL.
I will properly clear it and then see if it comes back.
If it still comes back i may just put the airbox back on.
Has anyone ever ran the airbox with no resonator before?
If so, is there much induction noise?
Posted 07 February 2011 - 11:40 AM
google, Laminar air flow.
This is the main reasons why pods blow.
