At 60kph - 4th or 5th gear?
Posted 25 February 2011 - 02:09 PM
What are your own experiences on this subject?
Those of you who are cruising around in 5th gear, is the economy any better or worse than using 4th gear.
In the B4 the revs go from about 2.2k to 1.5k, which in theory should give you greater economy, but my boost gauge reads a lower negative vacuum level in 5th gear therefore higher engine strain.
Also, there are zero hills in Adelaide so using 5th gear shouldn't be a problem.
Discuss.
Posted 25 February 2011 - 02:14 PM
Hard topic. I run 4.11's which is what the B4 runs, think 3rd and 4th are the same ratio... I usually go in 4th, or whatever gear gives me the lowest RPM - not because of economy (my car doesn't do that), but simply to get the thing to be quiet.
Posted 25 February 2011 - 02:15 PM
1st.
I find if I'm in 5th at 60, I'm constantly going down to 4th, then back to 5th and on and on.
It's fairly hilly here so that might make a difference.
I drive an Outback so economy is always good. Meh
Posted 25 February 2011 - 02:16 PM
Grow-up Dylan. This is a serious conversation.2nd. Keep it in that nice RPM ready to piss off. I also drive through school zones (40km/h) in 1st.
My 1st gear goes up to 60, so should I just go from 1st to 5th? Or just drive around in 1st gear at 8000rpm?
Posted 25 February 2011 - 02:31 PM
i go 5th to keep it quiet.. i can still pull most hills fine, but i would usually drop to 4th.
if I'm doing 50 ill even go to 5th, until i need to accelerate, but if its a constant speed i can stick to 5th
Posted 25 February 2011 - 02:32 PM
HAHAHA.Grow-up Dylan. This is a serious conversation.
Yeah, I got my RPM limit increased to 8250 so I can go that little bit faster in first gear
Posted 25 February 2011 - 02:33 PM
we drive Subaru's
Posted 25 February 2011 - 02:35 PM
5th, manual says 4th till 70??? WTF
Yeah, I wouldn't go 5th gear at 50. At 60 it's probably the lowest I would go in 5th.
Posted 25 February 2011 - 02:38 PM
Posted 25 February 2011 - 02:39 PM
5th mostly. Economy is good for me - 11L per 100km
Nice.
How big is gen2 sedan fuel tank?
I am lucky to get 300km/h out of a whole tank lately
Posted 25 February 2011 - 02:41 PM
Nice.
Oxygen sensor?
I usually get around 430km per 50L (when the light comes on) which is a bit over 11L/100km
Posted 25 February 2011 - 02:51 PM
When i went over to make love to Tom and have a romantic lunch... i got 700K out of a tank. (56L)
Posted 25 February 2011 - 02:53 PM
Your driving like a sissy.... 18L/100 is where it's at!I usually get around 430km per 50L (when the light comes on) which is a bit over 11L/100km
Posted 25 February 2011 - 02:54 PM
anything from 1st to 5th (or 6th if it's there). Close thread.
Yeah, and that worked out well for you, didn't it Buzz?
Posted 25 February 2011 - 02:56 PM
Posted 25 February 2011 - 02:59 PM
3rd
4th for sure.
Make up your mind you indecisive women.
