Posted 18 October 2011 - 06:12 PM
I took it to a good local mechanic today and he's scratching his head. The compression on the passenger side cylinders is 180psi, the drivers side measured 120psi. The injectors are getting pulse and there's plenty of spark from the leads (I replaced the leads and plugs a few months ago, so they shouldn't be the problem). He suspected a the timing belt may have jumped a notch, but the vacuum test didn't show anything amiss. Mind you, I'm not familiar with a vacuum test, so I don't know what it does and I don't know if it would show if the timing was out.
From doing my research on here and other sites, I can see it's an interference design, which leads me to believe that if it had jumped a tooth, then it's likely I would have damaged valves. But when that happens it's a rather audible affair, I have not heard any bangs, clunks or anything like that. The only difference is the exhaust note is lumpy (kind of like it has an aftermarket exhaust) and the engine shakes a lot, almost like it has a stuffed engine mount, which it doesn't have.
I'm unsure of what to check next, could testing for injector pulse have no bearing on whether or not they're actually squirting fuel? Could it just be faulty injectors? Not having done a compression test myself, does the pressure reading come from when the engine is running? Does anyone have any idea on what we should look at next?
The pulleys are all ok too, no problems there.
Cheers all, I'm really stumped and this is my everyday car, so any help that can be offered will be greatly appreciated.
-Paul
Posted 18 October 2011 - 06:36 PM
Is it possible that your valves are out of time and staying Slightly open causing the low compression?
Posted 18 October 2011 - 06:49 PM
I'll give him a ring again and let him know your story. Could well be a very similar thing. Thanks for that
Posted 18 October 2011 - 06:52 PM
Sounds VERY much like a cam timing issue on one bank.
Vacuum test is good for a pointer but the only way to confirm the cam timing is OK is to look at the timing marks.
Is it twin cam?
Edit:
I would think that the vacuum readings would be different to a 'normal' engine as one (or two) cams is only running half the engine.
Should the cam belt jump on say a inline 4cly, it would effect all cylinders.
Posted 18 October 2011 - 09:29 PM
Posted 18 October 2011 - 10:30 PM
If its only jumped a couple teeth the valves might'nt have contacted the pistons yet.
Make sure the tensioner is in good order when you look at it and that none of the idler pullies have siezed ar are tight.
Posted 19 October 2011 - 07:14 AM
Did you use a new timing belt kit when fitting this motor?
Posted 19 October 2011 - 07:37 AM
Hopefully you get to the bottom soon, does very much sound like a timing issue though.
Posted 19 October 2011 - 11:19 AM
New timing belt kit is going on today and I said to replace the hydraulic tensioner regardless. I know it *might* be ok, but I'd rather be safe than sorry. Knowing my luck, if I don't do it to save cash, it'll bite me in the arse later when it all goes to poo lol.
A sincere thank you to all for your input, it has been really helpful in getting to the bottom of this.
Interesting thing to note, the problem occurred at my mate's property, and I had to drive from Kandos to North Richmond on only 2 cylinders and it coped quite well...tough motor!!!
Posted 19 October 2011 - 08:43 PM
Posted 20 October 2011 - 07:27 AM
Posted 20 October 2011 - 08:44 AM
Oh yeah, that too.
Posted 20 October 2011 - 09:24 AM
Posted 20 October 2011 - 02:36 PM
#1 on the ignition coil has packed it in today. *screams*
Looks like I'm on the hunt for one of those now too. If anyone knows of one available, please let me know
Posted 20 October 2011 - 03:50 PM
Good advice!
Replace both coils if possible, and the leads.
Posted 20 October 2011 - 04:03 PM
Also tagged with one or more of these keywords: compression, engine, timing
Model Specific →
Impreza / WRX / STi →
Engine / Driveline →
NA Impreza engine part compatibility?Started by Sweezyboi, 27 Sep 2019 NA, Subaru, Impreza, Engine and 1 more... |
Model Specific →
Liberty / Legacy / Outback →
Engine / trans compatibilityStarted by Itsowrong, 28 Oct 2018 trans, engine, Liberty |
Tech: The basics →
Electrical/Electronics →
Check Engine Light Is Constantly On!!!Started by Luke96, 08 May 2017 subaru, liberty, check, engine and 5 more... |
Tech: The basics →
General →
1996 GC8 Impreza Ej22e Phase 1 Conversion ?Started by Kurt, 07 Apr 2017 Conversion, Engine, Loom |
Tech: The basics →
Twin Turbo →
Gen 2 EJ22NA to EJ20TT conversionStarted by zacsuby, 14 Nov 2016 Gen 2, twin turbo, EJ20, EJ22 and 3 more... |
