Alternator plug wiring... HELP.
Alex 23 Oct 2011
Doing alternator plug replacement whilst half asleep wasn't a good idea.
Square plug alternator circa 1997.
White wire where...black wire where? (whilst looking at alternator from the front of the car, top down)
Please help!
Please help!
Alex 23 Oct 2011
spanks!
only reason i asked is that i googled, and found a contradicting image.
that looks orright to me!
spanks!
Adam 23 Oct 2011
Should put a disclaimer, I dunno what loom or alternator that is possibly v3 sti?
Though the wire size should also help you!
Glad I could help rather than be helped for a change
alexGT 23 Oct 2011
shroud that main +ve terminal on your alternator adam, potential big short there.
Adam 23 Oct 2011
I actually noticed that the other day, I couldn't work out if there was meant to be one on there or not!
Where would I get a shroud from?
AussieTemplar 23 Oct 2011
Alex, sounds like you had the same problem as me..
My old alternator was that type of plug.. The one I got from shaz was just a two pin.. I didn't know which one went where.. so we took a guess and it was right. Was risky as ****, but it worked.
