Secondary Air Pump Maintenence
SG 06-08 XT Forester
32 replies to this topic
#1 Morgan
  • 25485 posts
Posted 04 November 2011 - 03:26 PM
This seems to be a common problem for the late model SG Foresters.
Thought I'd start a thread to gather information and discuss the topic as I plan to remove mine before it becomes a very expensive problem!
Some links for reference:
http://www.subarufor...uestion-101091/
http://www.subarufor...tml#post1061979
http://forums.nasioc...d.php?t=1209260
http://www.subarufor...cleanout-99369/
What the pump looks like in your engine bay:
If you have any experience, knowledge or suggestions on the issue, go nuts :)
#2 Shaz
Posted 04 November 2011 - 03:39 PM
#3 AussieTemplar
  • 2586 posts
Posted 04 November 2011 - 04:16 PM
I lold ^.
#4 RX25SE
Posted 04 November 2011 - 04:22 PM
Morgs, I CBF reading the links.
Is this part of the turbo system or is it a supported OBDII monitored system?
#5 bobbyjimmy
bobbyjimmy
  • 1287 posts
Posted 04 November 2011 - 08:36 PM
Cosworth (and others) block off plates + retune (so get rid of the CEL) = win.
Pumps air into the manifold at cold start, tricks emissions.
The pumps and valves (each side of the manifold) shit themselves and are ~$1500 for a pump and $700ea for the valves.
#6 alexGT
alexGT
  • 1970 posts
Posted 04 November 2011 - 09:09 PM
disable the code and leave it.
#7 Morgan
  • 25485 posts
Posted 29 November 2011 - 10:03 AM
Have just bought these blanking plates and gaskets
Thanks Iain for the link.
http://www.kstech.bi...te-block/Detail
#8 Matt
Matt
  • 4380 posts
Posted 29 November 2011 - 10:16 AM
Talked to Michael (MSR) about this the other day just out of interest....his words were "yeah theyre known to shit themselves? but who cares? it doesnt hurt anything when it does,just gives a CEL.. and why waste money on fixing something that aint broke? just wait til it dies, than block it off and disable the code in the ecu (as Alex said above)"
He thinks your looking too much into it :)
#9 Morgan
  • 25485 posts
Posted 29 November 2011 - 10:27 AM
I probably am...
#10 Marv
Marv
    Rapist
  • 1607 posts
Posted 29 November 2011 - 10:28 AM
I guess it means Morgan won't have to shell out the money to fix the issue before he sells the car...? He can pull these bits off before he sells the car... bingo, totally stock car.
That's the reason I figure Morgs was doing it?
Pork Hunt Motorsport
#11 Adam
Posted 29 November 2011 - 10:29 AM
What does MSR know anyway....
#12 Morgan
  • 25485 posts
Posted 29 November 2011 - 10:34 AM
Yeah pretty much mate. I'm happy to throw a yellow at this to prevent the inevitable and then when the time comes to sell, I can put it all back together...
#13 Morgan
  • 25485 posts
Posted 29 November 2011 - 10:37 AM
Interesting. After trying to decipher the multiple threads on the issue, I thought it did cause damage when it went - hence costing between $2500-5000 to fix.
Perhaps that quote was for a new pump + components altogether? Makes more sense.
#14 Shaz
Posted 29 November 2011 - 11:01 AM
I still stand by my post above.
#15 Morgan
  • 25485 posts
Posted 29 November 2011 - 11:04 AM
Jeremy Clarkson says your post is useful
#16 alexGT
alexGT
  • 1970 posts
Posted 29 November 2011 - 08:29 PM
again, disable the codes. if the pump fails (which is 99% of the time) the valves will stay shut anyway so there is no difference to performance anyway. (it only runs for startup to reduce emissions).
#17 Matt
Matt
  • 4380 posts
Posted 29 November 2011 - 08:58 PM
^^^pretty much what Michael said^^^
#18 Alex
Posted 29 November 2011 - 09:47 PM
Give it a Viking funeral.
#19 Morgan
  • 25485 posts
Posted 15 May 2012 - 10:55 AM
Resurfacing this thread again.
I bought the blanking plates in the link a few posts up and they've sat on the bench at home ever since...
Was driving to work yesterday morning and I got a CEL (+ cruise control light flashing). Spat out the code P2444 (Secondary Air Pump Stuck On). Well surprise surprise!
Cleared the code after work but it appeared again this morning.
Next step is to delete the pump, block off the valves with the blanks I bought, disable the pump system and reflash the ECU so that it's not longer required.
Will keep you updated :)
#20 robwa
robwa
  • 1 posts
Posted 02 July 2012 - 10:59 PM
Any further info that you can give from the fixes that you have attempted ??
