BG5 Legacy v8 STi conversion
BJ BG5 22 May 2012
Car is running reasonably well but is showing signs of still running a bit rich, blowing black smoke in low to mid-range rpm, chugging (flooding) at cruise speeds and using ALOT of fuel even staying out of boost. For those who know a bit more about tuning than I do, does the AFR chart on the dyno sheet look like its running rich or not? The tuner said he left it a bit fat to be on the safe side but it just seems to be running a bit too rich to me. I am only running one CAT now as the dump I swapped to has no CAT, could this be the cause of the black smoke and rich fuel smell? Another thing is my CEL is on with code p0103- MAF high input. I have cleaned the MAF itself & connections also the air filter but still get this code. Time for new MAF I guess?? Could this also be contributing to my running rich issue?
The guy that tuned it (Steve Knight- Adelaide) is actually an EVO specialist but the guy that did the conversion for my put me onto him because other than S&J's (ECUTEK) there are limited options on flash tuning here in adelaide. Should I be getting back onto him about the tune being too rich or should I sort out my MAF & CAT issues first? Thanks for listening guys, any help much appreciated. Cheers, Brendon. - More pics of car in my gallery if ya interested!
BJ BG5 22 May 2012
nickknack 22 May 2012
A dyno sheet usually won't have a direct conversion to Nm on it. They calculate power by reading the Tractive Effort (whats on the RHS of the sheet). This is the force required to spin the rollers. Since its a direct force, without any direction, its only measured in Newtons. To convert this to engine torque, you need the following calculation:
The tractive effort is obtained by multiplying the torque by the total ratio of the power train and dividing this sum by the rolling radius of the driving tyres.
T = (TE x r)/(1000 x R)
Where:
T= Motor torque in Nm
TE = Tractive Effort in N
R = Overall gear reduction including both axle and transmission
r = Rolling radius of loaded driving tyre in millimetres
Example:
TE = 5400
R = diff ratio X gear ratio (eg 3.45 diff x 1.00 Auto 3rd gear = 3.45)
r = 326.60 mm (18" rim/ with 235/40/18 tyre combo)
(Stolen from ls1.com.au)
