Swap EJ20 to EJ25 help
Posted 08 July 2012 - 07:38 PM
Cheer!
Posted 08 July 2012 - 07:48 PM
if your cars a 98 RX (is it a gen 2 or gen 3?) it should already have a EJ25
Posted 08 July 2012 - 08:09 PM
Posted 08 July 2012 - 09:03 PM
Posted 08 July 2012 - 09:10 PM
Posted 08 July 2012 - 09:14 PM
Posted 08 July 2012 - 09:23 PM
Posted 08 July 2012 - 09:38 PM
0415 522 512
Posted 08 July 2012 - 09:41 PM
Posted 08 July 2012 - 09:43 PM
Posted 08 July 2012 - 10:26 PM
8 bolt block and a 4 bolt gearbox bolt together no problems.2.5L are 8 bolt mount arent the 2L 4bolt? someone correct me if im wrong...
Posted 08 July 2012 - 10:32 PM
Off memory one bolt is different the 4bolt had a stud to the starter on the 2.5L it didn't...
Posted 08 July 2012 - 10:41 PM
Posted 09 July 2012 - 08:45 AM
I believe its an issue using an 8 bolt box with a 4 bolt block, but you definitely don't have to do anything the other way around.
It's no issue. You tap a thread in the bolt hole and use a bolt. OR wind a stud in. OR drill the back of the bellhousing slightly to accept a bolt head and push it through from behind.
There's plenty of solutions.
Posted 09 July 2012 - 09:14 AM
I wonder if he could use the ej25 long motor and all the ej20 manifold, sensors etc.
Posted 09 July 2012 - 09:41 AM
Sorry, I didn't mean issue as in "shit, this thing ain't gunna fit", but rather it's more effort than just bolting everything back together the same way you took it apart.
Posted 09 July 2012 - 10:01 AM
Oh and its a DOHC
Posted 09 July 2012 - 10:02 AM
Yeah, all good my post was a bit blunt (pre-coffee on a monday blergh)
Posted 09 July 2012 - 11:42 AM
1998 SUBARU LIBERTY MOTOR. EJ25 ENGINE # 253090. Thats all the info i got i hope this helps
Oh and its a DOHC
Frying pan into the fire mate.
That's a Gen2 RX motor, which are are well known for blowing head gaskets. If you were going to bother spending the time and money converting, go for a Gen3 varient. the last thing you want is for the "new" engine to pop not long after you've finished installing everything.
Just a thought... what happened to the EJ20? If it's just the head blown, wouldn't that be a cheaper, less intensive and more reliable fix?
