What do I need to swap Brembos onto a WRX?
You can either
a ) Swap 04 Brembos over - easiest if you can find them
b ) Swap 05 Brembos over - a lot more work, though there are advantages to using the larger hubs and whatnot
Very cliffnotes version:
Fronts will bolt up, but you will need the rotors, pads, calipers, and bolts.
Rears, not so much, and you have to use a brake caliper adapter. I believe Ken@WRXBrakes has one, Dan@MachV has one, and Tom@Kartboy has one.
04-08 Subaru Brembo Caliper will swap on the any RS or WRX no problem. You will need the 04-08 Caliper and an 04 Rotor (5x100).
The to do the rears you ether need a bracket and the special rotor Brembo makes for the swap or you need to get an 04-07 STi Rear Hub Assy (04 only if you staying 5x100). However, you can swap to a 06-07 WRX rear Caliper (same as JDM 2 pot) and run a stock 06-07 WRX or 04-07 Legacy GT rotor with the special l bracket Kartboy makes for the swap.
The two main differences between STi and WRX hubs is the diameter of the e-brake assy and the mounting points on the hub for the caliper.
General swap information:
http://forums.nasioc.....php?t=1225904
http://forums.nasioc.....php?t=1389105
http://forums.nasioc.....php?t=1535742
Information about getting the rears on:
http://forums.nasioc.....php?t=1136862
http://forums.nasioc....hlight=brembos
http://forums.nasioc...ad.php?t=811621
What is pad knockback?
http://www.stoptech....s/knockback.htm
Why would swapping Brembos onto a WRX cause pad knockback?
http://forums.nasioc.....php?t=1165064
Is the WRX master cylinder OK with STi Brembos?
http://forums.nasioc.....php?t=1456630 *updated and better than the next link
I just want to swap the front Brembos onto my WRX/L/whatever.
What replacement rotor options do I have?
-dealer prices
-cheap options
-blingin' 2-piece options
What wheels clear the Brembos?
http://forums.nasioc...ad.php?t=448097
The pads that come in my Brembos dust too much.
What can I use for touch-up paint? My Brembos are a little scratched.
The original popular answer was Honda Inca Pearl or something like that. But some people have had better luck (a more accurate match) with... nail polish
http://forums.nasioc....highlight=inca
Can I use Evo/350Z Brembos?
CTS-V:
Evo to STi:
Evo to WRX:
http://forums.nasioc.....php?t=1453829
Can I paint my Brembos another color?
http://forums.nasioc.....php?t=1076545
http://forums.nasioc.....php?t=1262317
How can I repair the threads in my Brembos if they get nicked?
http://forums.nasioc....rembo helicoil
Thanks jac04!
How can I disassemble my calipers?
http://forums.nasioc.....php?t=1600335
Attached is a spreadsheet that calculates that stuff and has the piston sizes and effective diameters already in it.
brakemath.zip 105.15KB 2 downloads
Also, could we have a summary of what it takes to swap brembos? Something like this:
Brembos, like most other Subaru brakes, are interchangeable between models. However there are a few extra things that are needed.
Rotors:
The 05-08 STi has 5x114.3 rotors, where all other Subarus are 5x100. This means only 04 STi rotors will fit on other cars.
Rear Backing Plate:
The rear Brembos are 2-pot fixed calipers, and they will not bolt up to cars with 1-pot rear calipers. They will bolt up to an 06-07 WRX. To install them on another Subaru you need to swap backing plates (a pretty involved process requiring a press), or buy some adapter brackets. Kartboy manufactures adapter brackets and they are sold through various nasioc vendors.
Rear Parking Brake:
The STi has a 190mm parking brake. Most other Subarus have a 170mm parking brake. That means if you put 04 STi rear rotors on your car the parking brake will not work. Previously the options were to deal with it, have some spacers made to fit in the rotor, or buy expensive taller brake shoes from Godspeed in the UK. Fortunately DBA has started making a 5x100 Brembo rotor with a 170mm parking brake drum.
So, to swap brembos you need:
-Calipers and bolts (any 04-07 will work)
-04 front rotors
-kartboy rear adapter brackets
-DBA 2657 rear rotors
The 08 rear end is different and I don't think the calipers are interchangeable. You could use the 08 black front calipers though.
