Subaru fuel filter changes should be the same across most platforms / models up until 04 STI / WRX or 05 STI / WRX (or similar) where it moved to the fuel tank. What you will need:
- Phillips Screwdriver - for the hose clamps
- Eye Protection - To keep petrol from getting in your eyes in case you flick a petrol line while removing it.
- Rags - To catch any petrol that will dribble out of a hose after you remove it
- Fuel Filter - From your local Automotive outlet.
Ensure that you wear eye protection before you commence, to avoid petrol in the eye.
Locate the fuel filter and undo the two lines that run over the filter from the plastic clip. With a phillips screw driver, loosen both hose clamps and slide the clamps about as far down the hose as you can. This will give you a good spot to grip the hose and the clamp won't get stuck at the bump in the filters petrol line.
FuelFilter_1.jpg 93.54KB 32 downloads
Next, undo the clip type clamp that holds in the filter. It's around the outside of the body of the filter and lifts up and away to un-clip. Take the clip bracket off and put it aside. Take some rags and put it under the hose where it comes into the filter. Now remove the hose. It's best to rotate the hose back and forth around the filters pipe to break it loose, then pull it off. Sometimes this part can be a bugger. You may need to use pliers to rotate the hose loose (be careful not to damage the hose - if it gets cuts in it you will have to replace it). When the hose comes off some petrol will dribble out, so make sure you have a rag under there.
FuelFilter_2.jpg 86.39KB 30 downloads
FuelFilter_3.jpg 82.12KB 25 downloads
After the hoses are off and you have the filter out, remove the plastic clip from the top and put it on the new filter. There is a rubber sleeve on the old filter too that needs to be removed and placed on the new filter too. The rubber sleeve is where the clamp holds the filter in place. Notice on the new filter there is an in and out pipe. The in is toward the outside and the out is at the center. Put the new filter in place (don't clamp it yet) and attach the two hoses, slide the clamps up and tighten them back down. Don't go crazy tight, you don't want to go so tight you cut the rubber, just make it nice and snug. Now put the clip back on and clamp the new filter in place. After that, clip the hoses back in the plastic holder clip.
FuelFilter_4.jpg 138.19KB 30 downloads
FuelFilter_5.jpg 85.11KB 26 downloads
FuelFilter_6.jpg 106.41KB 22 downloads
Now start the car, it may take a few cranks, the fuel has to fill up the filter first. Let the car run and check for any fuel leaks. That's it.
