Hey guys,
so my seat belts were squealing and whistling everytime they were used, i didnt think much of it until a kid got in my car and said my car sucked because of it...(Gutted) so i did some research and found out how to fix it. There are a few of these on other sites but pretty sure Subyclub hasnt got one so i thought i would write one up. Its probably the most easiest DIY you can do. excuse my lack of technical terminology etc....
Car Model:
2002 Impreza RX
Time taken:
Start to finish 10-15 min
Tools needed:
1x flat head screw driver
1x stanley knife
IMAG0031 size test.JPG 241.93KB
9 downloads
Method:
Using flat head screw driver remove clip on the rear side of the seat belt cover pillar. It is located right near the rear door hinge.
IMAG0040re.JPG 237.84KB
7 downloads
then using your hands simply pry the rest off, its only held on by a lip
once the plastic seat belt pillar has been removed lay it flat on the ground. You will notice 3 raised plastic sections marked with crosses below
IMAG0033 plus cross re.JPG 363.54KB
6 downloads
Notice that one will have alot of fabric/dust on it. That is due to the seat belt rubbing on it, this is the cause of the whistling seat belt.
IMAG0035 re.JPG 442.06KB
5 downloads
using the stanley knife simply begin to cut this lip away
IMAG0041re.JPG 208.5KB
5 downloads
Until it is flush with the base of the pillar
IMAG0039re.JPG 254KB
5 downloads
i removed all three plastic lips although the top one is the one causing all the noise.
then simply place back over seat belt and reassemble. when placing the clip that was removed with the flat head screwdriver back in use your fingers to push the 4 point clip back together
IMAG0043re.JPG 162.03KB
6 downloads
and then insert.
really easy, simple and effective
DIY Fix Seat Belt whistle
Started by Jberg89, Sep 10 2012 10:22 PM
4 replies to this topic
Posted 10 September 2012 - 10:22 PM
Posted 10 September 2012 - 11:23 PM
Nice DIY mate. I'm sure there are a lot of people who'll find this one helpful!
Posted 11 September 2012 - 05:49 AM
Good DIY!
Posted 27 September 2017 - 10:08 PM
Randomly discovered this post and have now just fixed my car's squeaking. Cheers.
