98 outback ej25 problem
Posted 23 December 2012 - 10:58 AM
i have just replaced timing belt after it snapped.
i cant get the timing right.i have lined up the marks but #2 cylinder (front left) but the valves are hitting the piston.
Posted 23 December 2012 - 11:12 AM
When I shave heads and there is an issue with piston to valve clearance, I put Plasticine on the top of the piston and dummy assemble then measure the indentation in the Plasticine.
Posted 23 December 2012 - 11:22 AM
Posted 23 December 2012 - 11:33 AM
It's not something stupid like one bank is set 360deg from the other?
Can you feel (buy gently turning the cam wheel) if it is one side or both?
Posted 23 December 2012 - 11:40 AM
Posted 23 December 2012 - 12:12 PM
Posted 23 December 2012 - 12:18 PM
I think your problem is elsewhere.
Double check the cam timing.
Posted 23 December 2012 - 12:26 PM
here is a you tube link to do it
Posted 26 December 2012 - 08:16 PM
thanx for your imput
Posted 26 December 2012 - 10:22 PM
Glad to hear it's sorted.
Keep us posted on the install!
Nik
Posted 27 December 2012 - 10:13 AM
Did you do the old "wire down the spark hole" trick to find TDC?
Posted 27 December 2012 - 02:45 PM
Posted 27 December 2012 - 03:12 PM
