CHANGING FROM MANUAL ARMING TO AUTOMATIC ARMING MODE
NOTE: To change from one mode to another, you must have the keypad in
exit countdown delay (*741 flashing in sequence).
1 . lf you wish to change from manual to auto arming, start with the engine running. Turn the engine off and all the keypad 12
lights should come on and stay lit.
2. Enter your user code to enter exit countdown delay (* 7 4 1 flashingi n sequence)
3. While in exit countdown delay, press and hold down for at least one second, the number 3
The keypad system is now in automatic arming mode. You can now either start the engine before the keypad arms itself (random flashing pattern 40 seconds after exit countdown delay started), or exit the vehicle, lock the doors and allow the keypad system to arm itself.
While in automatic arming mode, the keypads system will arm itself every time the ignition is turned off, which means you need to enter your user code to enable the engine to start when you return to your vehicle.
Hope This helps anyon looking!
Arming Brant alarm system
Started by Trigga, Dec 17 2008 09:11 PM
5 replies to this topic
Posted 17 December 2008 - 09:11 PM
Posted 24 June 2009 - 03:10 PM
FYI. Waiting for the above sequence of lights after the engine has been switched off...
1...Valet mode (10 starts with no code)
2...Manual arming mode
3...Auto arming mode
4...Anti-hijack OFF
5...Anti-hijack ON
Posted 24 June 2009 - 03:14 PM
Thanks for the info, so to turn off anti hi jack i just hold down 4 after i turn my car off?
Posted 24 June 2009 - 03:19 PM
Yup. As per the original post, the keypad will go into a *741 flashing in sequence, that's when you hold down 4 until the car beeps/chirps at you.
Posted 24 June 2009 - 03:20 PM
awesome, i can finally get out of my car without it turning its self off! =)
Posted 17 July 2009 - 07:46 AM
This might help.....
