I knocked up this today. Not much to it, But may give others the idea.
Instead of crawling under the dash every time I wanted to check Engine codes. I thought I'd put some switches in.
You need, 2 switches of your choice, Wire, Plugs (for these I managed to source some from another members spare loom but I'm sure they are standard plugs) Instead you could use crimp on terminals aswell. Heatshrink
Step.1 Cut fit switches where you want them, I cut out the blanking plug I had on my dash.
Step.2 Solder It all together, Covering the switch terminals with heatshirnk. Obviously Green to green and black to black on either side of the switches.
Step.4 Plug into car's loom, test and then fit blanking plug back into dash panel.
Step.5 Enjoy easy code checking. (switches need better fitting i know )
6 replies to this topic
Posted 13 April 2013 - 08:38 PM
Posted 13 April 2013 - 08:44 PM
Nice and neat! Would rather not have the engine throw a code so often I need to make up switches for it though
Posted 13 April 2013 - 08:45 PM
That is obviously the best option
Posted 13 April 2013 - 08:46 PM
Good idea Adam.
V3 Sti Ecu's...they throw codes man...they just do.
Posted 13 April 2013 - 08:48 PM
I can't take the credit for the idea, I've seen it elsewhere. But thought I'd make it up instead of purchasing! Cost me about $5
Posted 13 April 2013 - 11:00 PM
Nice work dude. I have a similar set up in the Forester. Heaps easier than getting underneath the dash and finding the plugs!
#7 Guest_KONG_*
Posted 14 April 2013 - 11:23 PM
Good stuff mate.
Hope you don't have to use them too often.
Also tagged with one or more of these keywords: DIY
Tech: The basics →
Do-It-Yourself Guides →
General for swapping a Spec B 6MT and an R180 into a gen 3 LibertyStarted by timslib, 21 Oct 2018 nugg, liberty, h6, ez30, 6mt and 3 more... |
Tech: The basics →
Subaru Outback '07 - GX-204KH stereo - DIY Aux Mod - $2.85 total.Started by JonChaka, 01 Oct 2018 GX-204KH, Aux Mode, DIY |
Tech: The basics →
Brakes →
Help with replacing brake padsStarted by Paul-of-Duty, 09 Dec 2015 DIY, Brakes, Impreza, Maintenance |
Tech: The basics →
How to Import Monster like a proStarted by Barbbachello, 26 Feb 2015 Import Monster, DIY, Pro and 2 more... |
Model Specific →
Liberty / Legacy / Outback →
Body →
D.I.Y. vs G.I.D. Body RepairStarted by RK2770, 10 Jun 2014 Gen 3, Wagon, Dents, Paint and 3 more... |
