Groaning noise whilst turning left
Posted 07 May 2013 - 11:57 AM
My car is making a groaning noise and a slight viabration whenever i turn the wheel left. I read that it is most likley something to do with the power steering. I was planning on replacing the hoses attached the resovoir.
Just wanted to check if anyone else has had any experience with this?
Car is a manual Suby outback 2000.
Thanks!
#2 Guest_KONG_*
Posted 07 May 2013 - 01:25 PM
Posted 07 May 2013 - 01:35 PM
I don't think just replacing the hoses will do much mate. Are they leaking? How is your fluid level?
They arnt leaking, and the resovoiur has plenty of fluid. I found this which sounds like it had the same symptoms.
http://www.scoobymod...711.html?t=3711
Other things I am thinking,
-tyres
-the boot cover on the left side has a small crack in it
-CV joints.
Posted 07 May 2013 - 03:08 PM
Posted 07 May 2013 - 04:44 PM
2000 RX Gen 3 Liberty - Sold
Posted 07 May 2013 - 05:07 PM
You could try bleeding it, but I doubt you will get the air out.
When the pumps get old the shaft bush wears and the seal can't cope with the shaft running slightly off centre. This means the pump is sucking in a small amount of air and the aerated fluid is what's causing the noise.
The pump will need a reco.
The only other thing is the two O rings on the pump inlet fitting, if these leak the pump will also suck air.
Neither of these faults cause an external leak of fluid.
Posted 07 May 2013 - 07:40 PM
As above, air in the lines.
Thank you Jase! This is exactly what is happening to mine! Gets air in it, but no source of leak. Are these DIY rebuildable, or should i just remove the pump and send away to get re built?
Posted 07 May 2013 - 08:04 PM
Posted 07 May 2013 - 08:40 PM
My GenIII needs a reco but doesn't make air....yet.
If I do it before I sell it, I may do a DIY.
Posted 07 May 2013 - 09:42 PM
Just a tad.Interested in DIY rebuild also! My pump is embarrassingly noisy!!!
Posted 08 May 2013 - 10:44 AM
Probably best to send it out as prolonged use with aerated fluid can damage the pump beyond a DIY repair.
would love to see this aswell. is it worth just spending $200-$300 and just replacing with a new pump?
Posted 08 May 2013 - 12:20 PM
would love to see this aswell. is it worth just spending $200-$300 and just replacing with anewRECO pump?
A new one is $1900 , reco's are $200-300.
For the time, parts and lack of warranty a reco would be well worth considering.
Posted 08 May 2013 - 12:31 PM
Posted 08 May 2013 - 12:42 PM
Will Ichiban do it?
